PIXMA G3200 Print Head Availability
Are these available from anyone? Can't find them. I've cleaned and cleaned manually and through the APP, no go.
can get it to print in a smaller size
I got the printer yesterday. I had to get a new printer because my mx532 won't work with my new chromebook. So, set it up and after a lot of agravation, the chromebook sees it for print and scan. Whoopee. I print my first doc and the print head is ...
TS5120 is permanently preset on templates and even after resetting all. II guess it is a SW problem. I updated firmware but it did not help.
I have the dreaded 5B00 error on my G2200. I removed and cleaned the 2 ink absorder pads but how do I reset the error to make the printer operational again? I found about a half dozen different procedures online, but none work to clear the error. Doe...
I want to switch from USB connection to Wireless, but the instructions say to push WPS on my router. However, I don't have a router anymore. My internet connection is through Xfinity. The connection box (xfinity) doesn't have that button. Can anyone...
I know there is one in the States, is there anything being done in Canada?? I have a MX892 that will not work. I have tried all the suggestions.
Does anyone know where I can find replacements for the waste ink pads and there was a sponge that was also saturated in ink. Are these available anywhere?
I just purchased this printer and I am trying to get past the printer alignment portion of the setup, but it keeps giving me an error 2900 message. It tells me to seek out help in the manual, but I am not seeing any information on this error message...
20220902_201012.jpgI have tried both cleaning and deep cleaning the print heads as well as replaced the large black ink and still getting same results. Any help would be appreciated.
There's no Media Type listing for PT-101 photo paper for my new G620 printer. What listing should I use? Printer rejects Photo Paper Glossy II. Using a Mac.
I've downloaded the IJ Scan Utility Lite, but the option to scan double-sided in the ADF is not showing up in my menu as this online manual shows here: https://ij.manual.canon/ij/webmanual/ScanUtilityLite/M/3.1/EN/SUL/sul-009.htmlIs there a patch I n...
can i just use black ink i dont need color ink i have a pixma 2220
Here is what I'm suddenlu getting when I try to print on cd.Not only is there a color issue, there are lines across part of the cd.You can see it across the face and the Baer logo.The magenta ink is showing low but I don't thin changing it will solve...
My much loved MG5320 now has the dreaded B200 error. I've installed new ink cartridges, cleaned the print nozzles with water and alcohol and cleaned the print head with alcohol on a micro fiber cloth to no avail. HELP!
| Subject | Author | Posted |
| 09-10-2026 04:51 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
