Desktop Inkjet Printers
Printer Won't Print Unless I Power It Off and On
My printer does not print unless I power it off, and then back on. Also works if I unplug it for 5 minutes. I bought this mega tank printer with excitement, thinking I could print photos for a long time. Now it won't even print color, and all the tan...
sparzat by • Apprentice
  • 1462 Views
Replacement ink pads and sponges for PIXMA iP8500
Does anyone know if I can find replacement waste ink pads and sponges for the Canon PIXMA iP8500.  It works great, but it's old and needs new pads.  If not, can anyone recommend a comparable replacement for quality photo prints?  Don't need an all-in...
i have a ts9521c printer that just quit printing
my ts9521c just stopped printing from my laptop but will print from my iphone. it printed 3 copies and then just quit but will go through the motions of feeding the paper through. i deleted the printer and reinstalled it but still won't work. i must ...
No paper for MG2522
I am using my MacBook, connected to my MG2522 printer by USB. I am trying to print a 4x6 glossy photo, which I have registered with the cassette settings, however every time I try to print it says "Support Code 1000: There is no paper." Help me pleas...
TS6020 cassette tray not feeding paper
Hello All, I have a TS6020 and I cannot get my printer to print from the front cassette.  I get a Support Code 1003 that there is no paper loaded in the cassette.  However there is paper loaded in the cassette. The guides are aligned and everything e...
mhallo64 by • Apprentice
  • 3983 Views
  • 3 replies
  • 3 likes
cannot find G3202 printer on setup website
I was recently given a Canon G3202 printer.  I have gotten to the stage of the setup where I need to get on-line and find my model so I can continue setting up and connecting my printer.  Only it appears that my model number is not available any long...
PIXMA iX6550 Error Message
Have currently purchased new Acer computer running windows 11. Have downloaded the appropriate driver and when trying to print test page or other shows error on screen. USB cable is fine and is connecting to laptop Please advise on how to connect and...
proserv by • Apprentice
  • 1182 Views
PIXMA G3200 will not print black
I have cleaned twice, deep cleaned once and system cleaned once. Test pattern after each is the same. Colours good, no black. Not poor black but ZERO black. Visual inspection shows the ink tubes are all full. This unit is on its first refill.
MX922 Vertical line on copies
My MX 922 leaves a thin vertical line on copies when the original is fed through the upper feed.  No line on documents sent from PC or documents copied from the scanner glass. I've performed all the listed cleaning steps. TIA
smiley47 by • Apprentice
  • 13010 Views
  • 8 replies
  • 2 likes
PIXMA MX882 The ink absorber is almost full.
I have a Pixma MX882 that is displaying this message. I can press OK to keep printing but probably not forever. Yes, it's 10 years old but otherwise works fine. I would like to send it in for repair since I've read that it can be disassembled, the ab...
Help Choosing!!
FUNCTIONS NEEDED: Borderless, high-quality photo printing, copying, and basic document handling such as automatic document duplexing. For a home office with very low volume. What canon printer would you recommend? Thank you for any suggestions! Cheer...
Sajako by • Apprentice
  • 1155 Views
