Desktop Inkjet Printers
Pixma MX922 UV Black Light Ink ???
Trying to find a personal printer Company that sells a machine that prints with UV Black Light inks (home use 8x11). I own a Pixma MX922 personal use all-in-one printer, but there aren't any of these cartridges for it. Why?  In this age of designer s...
MG7520 printing stripes and streaks
Pixma MG7520 printer will not print correctly. Everything is printing in stripes and streaks. Don't know if it's a bad print head or clogged nozzles or something else. Have deep cleaned a few times. New ink used and even tried other inks. The printer...
mg5722 paper jamming
I have an mg5722 printer.  It has started to jam.  It started out that it couldn't recognize loaded paper but is now jamming every time it takes paper.  It jams at the very front of the paper and is easily removed from the input tray.  That being sai...
jgw0 by Contributor
  • 2678 Views
  • 2 replies
Ink Levels for the PIXMA G6020 Printer
Hello, My father owns the Canon 6020 Printer. The printer is not printing in color (only black) I looked at the ink levels and they are all at the second line (not low enough). Should I have him flush the system to correct this or does he have to pur...
PIXMA G3100 Ink Compatibility
It is the same printer as the canon g3100 and g3200, I know that the g3100 is only sold in Latin America but literally they look and have the same specs apart from the name.Can I use the same ink for both printers?
Resolved! Unable to Install PIXMA MG2520 Driver
HiWindows 8.I have downloaded MG2520 drivers file win-mg2500-1_1-ucd.When I atttempt to run the application win-mg2500-1_1-ucd, i get Infromation Acquisition Error message "failed to acquire information on the driver and software. check the network c...
aldeutsch by Contributor
  • 144298 Views
  • 16 replies
  • 6 likes
Resolved! Canon Pixma TS9521C printing fuzzy lines
My 2 year old printer has just started printing fuzzy lines. I get just a few good lines and the rest are faded and partially gone.  I have run all the test and cleaners with no change.  Can you help?
pslane1 by Contributor
  • 5627 Views
  • 6 replies
TR8620 - Error Code 6951
Hi,I bought the printer 1.5 year back and hardly used it. Setup the printer few months back and it worked fine. Then didn't use for couple of months and turned it on 2 days back and suddenly seeing error code 6951. Tried turning off and turning back ...
