Canon Pixma TS9521C printing fuzzy lines
pslane1
My 2 year old printer has just started printing fuzzy lines. I get just a few good lines and the rest are faded and partially gone.  I have run all the test and cleaners with no change.  Can you help?
@pslane1,
This is indeed helpful.  One of your black cartridges appears to be clogged, near empty  or at fault etc.
Run a standard cleaning to see if this helps.  If by chance the cartridge is at/near empty, it should be replaced.
This may also be helpful:
Canon : Inkjet Manuals : TS9500 series : If Printing Is Faint or Uneven
6 REPLIES 6
ArthurJ
Did you print a nozzle check after the cleanings? If so, could you attach a picture of your inks and nozzle check to your reply and we can troubleshoot further.
Will do.
Let me know if these will do.
@pslane1,
That fixed the problem!  So glad it was that fixable.  Although the cartridge had a good bit if ink, I replaced it.  Thank you much!
shadowsports, tried to print a document tonight and I'm having the same old problem.  For sure it's a black ink cartridge so I am going to replace the other black cartridge as soon as I can.  If you know of any other tricks I can try let me know.  Thanks.
