PIXMA MX922 B200 CODE
Printer comes up with support code and said turn off and contact support. They said to unplug it for at least 30 sec and plug it back in and turn on. Same result and they said sorry could help try a tech forom
old black ink cartridge came right out, new black ink cartridge will not engage, appeared to be too big measured with old cartridge and it’s the same size and number. I can take the color cartridge in and out no problem
Hi friends....i have a canon mx922...it stopped printing colors. Check Nozzle test prints only in black. I did deep cleaning several times. I did reset the printer, updated firmware. I even removed printer head and cleaning nozzles with water. There ...
I took my old (but trusted) Pixma MP160 with me on a 600+ mile drive (mostly/only highway), and when I arrived I get an E5 error. It seems to have to do with the color cartridge, but I cannot solve it. Have tried the possible solutions here and here ...
Our PIXMA mx922 prints blurry. I have already cleaned the encoding strip with hot water.When I print a black and white text document. some lines on a printed document are sharp and crisp, while others are faint and blurry. These crisp and blurry li...
Hi All, Brand new G7020 in place and playing with it to learn how to use the features. What on earth is the "manual duplex" mode I can select in the IJ Scan Utility Light software? Does this mean that I put my stack in the ADF facing up, and then t...
Something weird happened to printer. It prints correctly from computer or direct from phone. When I try to direct copy from a scan it will only print in a little spot. It takes whole picture and reduces it to miniature size. I have reinstalled softwa...
Trying to help a friend who's been frustrated by an old multi-function and issues with Windows 11.I'm finding that Windows 11 is a throwback to Vista in many ways when it comes to MFPs? He's the 2nd person asking me for help...He's looking at the Pix...
I got a Canon TS5320 Pixma from my mom, it worked perfectly for her. One day it has low-ink info on it, so I changed the carteges. and since then it has not printed well at all. It takes nearly 4-5 hours to print anything, and when it does 90% of the...
The printer thinks that there is something in queue. The error message says to cancel printing, turn the device off, and then turn the device back on. I can't cancel the printing. Selecting stop doesn't clear it. I've turn the printer off and back on...
Does PIXMA MG3620 print from Mac OSX 13.1 Ventura?
1D75F5F9-8A19-46BF-AF5E-4E5B363DD96D.jpeg this small clip fell out of the printer after a paper jam was cleared. It does NOT look broken but I cannot figure out where to snap it back in. Is there a parts assembly I can reference? Thank you!
When I print anything, there are "strips" of content that are much, much lighter than the stuff on either side. It looks like the roller might have lower spots where the ink doesn't coat the roller enough to print properly. Is this something I can ...
My printer cannot seem to print envelopes. I have never had this problem before. The envelope either gets jammed in the back of the printer or prints off-center. This is a new problem after using this printer for a few years. Any help would be apprec...
| Subject | Author | Posted |
| 09-08-2026 06:01 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
