MegaTank Ink Delivery Tubes - Full or Not?
elected
I have printed about 100 photos with my PIXMA G6020 with no issues. The photos look beautiful, and the ink levels have not changed. I opened the Ink Fill/Print head compartment and noticed that the tubes that deliver the ink from the reservoirs to print head are not full of ink and instead full of air. I do not know if this is an issue or not. I do not have problems printing, no error codes, and all the colors look accurate. I have checked around the forums and, in the manuals, but it does not mention this.
I have not performed any cleaning and the only maintenance option that might do what it says is ‘Ink Flush’ which ‘Fills the ink tubes and the print head with ink’. I really do not want to do this unless necessary as it consumes the most ink.
My question is: Should I perform an Ink Flush even though I don’t have any issues right now? Maybe a preventative maintenance cleaning? Do any other MegaTank consumers see the same thing, and this is normal? Should I just leave it alone?
Thank you for all who can provide context.
1 REPLY 1
ArthurJ
Hello,
Since there is no print quality issues, I would check the lines again after another print to see if they are still full or air or if more ink has filled the line.
Performing Ink Flush frequently will rapidly deplete your printer's ink supply. I only recommend performing an Ink Flush only when necessary. If this case, the printer would not require a ink flush.
Friends and Family
