PIXMA MG2120 Chromebook drivers needed
I have a Chromebook that I am trying to set up a Canon MG2120 with but don't have a driver. How should I proceed?
1. Mg3620 Printer is using wireless and the network address has been verified.2. The Canon Print app using wireless will print successfully from the chromebook.3. Chromebook recognizes the printer and is Connected.4. Chromebook native printing will s...
Hi I purchased this printer in Dec, 2022. It has been okay with my older router but I recently replaced my rounter to wifi6 mesh and the printer won't connect with this error code.I found one post which mentioned another user had the same issue and i...
HAVE A PROBLEM WITH MY PIXMA MX922 PRINTER.I currently have a Cannon MX922 printer, which has been a "work horse"; Unfortunately, I've recently discovered distortion with BOTH the text print or graphic printing, with an emphasis on the edges of the ...
I just bought the Pixma ix6820 and I'm trying to print a custom size (7x10). I update the size in my print drivers AND each time I click print in my photoshop softward (GIMP) but it continues to switch back to letter size 8.5x11 as soon as I click th...
Realizing I should have done my research before purchasing - I'm wondering if there's any way to install this printer to an air-gapped computer. The Master Install file forces me into a flow that requires a connection to the internet in order to pro...
The printer is stuck in a random scanning loop. It randomly scans when idle and then gives an error message that an unexpected error occurred and is discontinuing process with the OK at the bottom. Click OK and it goes away for about 20 minutes and t...
I have an MG7720 printer. Recently, it has started having black smudges on every picture I try to print. Most of the time it's on the left side, but occasionally on the right. I have cleaned, deep cleaned, cleaned the bottom plate & rollers. The only...
I have a Canon TS6420a printer, purchased 10/2022, so just five months past the one year warranty. When the black ink cartridge (260) ran out I put in a new Canon ink cartridge, but then got the error message 1430 “the ink cartridge cannot be recogn...
Microsoft Word’s page size setting is standard "letter" size (i.e. 8.50 x 11.00) in my computer, as I desire. However, when I save a Word document, the resulting measurements are 8.27 x 11.69 (metric). That's also known as "A4". Technical suppo...
I have a 9521C I am having a massive issue with. The colors are super light and it will not print text at all. I have done the cleaning methods, I have changed paper, I have done the alignments, and nothing seems to work. I have changed out the ink m...
This printer was working great until a couple days ago when the black started to fade, and now it doesn't print black at all. I've tried all the cleaning and deep cleaning steps and nothing works. Please help!
Our new printer Pixma G6040 has a small LCD display screen. The intensity is really low - almost unreadable. Is there a way to adjust the light? I can't find any option in the manual.
I get the message: "Support Code 1000 There is no paper in the rear tray.Check the following, than load paper and select (OK). -Align paper guides with the paper. How to clear OK" I don't want to print from the re...
G3270 Is typical garbage that can't perform basic functionsWhy on earth would printing black on plain paper be something that a printer can not do in 2024? The only way to get black is to adjust the settings to DARK and high contrast then turn off bo...
| Subject | Author | Posted |
| 09-18-2026 11:59 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
