05-04-2023 12:09 PM
The printer keeps giving me error code 1003, but paper is loaded correctly, and even going through the reset process it just won't print, and gets stuck in the que. I can however print a Test Page, but nothing else.
05-04-2023 12:32 PM
Tried cleaning the rollers, but did not help
05-08-2023 01:04 PM
Are you able to make a copy directly from the printer itself? If so, this will help narrow down if this is a hardware or software issue causing the error.
05-08-2023 06:45 PM
No, the paper will not leave the feeder tray at the bottom, so there's nothing to print on.
