Printer Problem
The printer says "error paper output slot the paper is jammed. Clear the paper and press OK. The orange light is on. Have cleared jammed paper and will not work
I've been successfully using a DR-2580C scanner on an old Windows XP laptop for several years. I now have an Acer hybrid machine with Windows 8 Pro and a SINGLE USB 3.0 port. I'd like to use my scanner with this machine. I've installed the 2580DRIT_V...
Hi, I have a user that just received this printer and it was setup. It was working and today the printer says offline. We have rebooted the computer and the printer (being used wirelessly). Tried to print a test page and it says that the printer is o...
My MX880 is printing in the upper left corner. Yes, it is set to letter size. It prints pdf's this way, not Word doc's. Please help,this really screws up my business! Thanks.
Hi Everyone First Post Any help welcome Bought MG 5350 few days ago Everything worked on installation However cannot now scan to PC Seems MP Navigator required Downloaded file from Canon Website get error notice saying it cannot be opened Tried reins...
I have a problem on prtinter scanner pixma MP145. cannot communicate with scanner.cable may be diconnected or scanner may be turn off.check status.scanner driver will be closed. what's the solution?
Anybody find an uncomplicated way to print from an ipad4-64, ios6 to a canon ip100, bluetooth enabled.? There is an app called print central (Eurosmatz) at the appstore however it has to web shared. Any ideas would be appreciated
I got a PIXMA MG5320 (because my PIXMA MG6120 would not print from my phone or iPad). But now I am reading the fine print and am concerned by the warnings that it will not work with my MacBook Pro OS X 10.7.5 I have read that Canon has 'solutions' t...
My i6500 will not print. It says ERROR. It will not go online either. Anyone help please?
Can you please help me? Pixma 495 I get the message: error 5200. My black ink is new. My color ink is emty. I only want to use the black ink. Why doesn`t the printer print? And why the message? Best regards Judith Vahlenkamp
I have been running my MP990 using a WiFi connection. I had to replace the printer with another MP990. I can still use the scanner function using the Win 7 laptop but not on the desktop XP. With XP, I get the following message: Cannot comunicate with...
I print from various applications and from MS Word there is no 2-sided option to uncheck...even in every dialoguw box and window I try and find one. It printes double sided EVERYTIME and it is starting to actually waste paper as I am having to reprin...
Hello, BOTTOM LINE: Can I change the Print Quality setting when printing my artwork on a printable disc? I recently changed from an Epson R220 printer to a Canon MG5420. Both allow direct printing onto printable CD and DVD discs. I changed printers b...
I would like to know what is the advantage of using the Auto Scan facility of a scanner. I would like to know also what is the advantage of saving a document that we have scanned in a PDF format instead of in a OCR format.
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
