Printer Problem
Dawnmac1
The printer  says "error paper output slot  the paper is jammed.  Clear the paper and press OK.  The orange light is on.  Have cleared jammed paper and will not work
1 REPLY 1
Stephen
Moderator
Moderator
Hi Dawnmac1!
So that the Community can help you better, we will need to know exactly what Canon equipment you're using,  and the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet). Any other details you'd like to give will only help the Community better understand your issue! Thanks and have a great day!
