My canon MX850 is not responding to my computer and won't print documents
My canon MX850 printer is not responding to my computer and will not print any documents. Please help!!
I reinstalled my Canon MG5320 software and drivers multiple times, and neither the Solution Menu EX nor the MP Navigator EX 5.0 screens appear with the applications start. I have no way to change the destination file for my scanned images.
Hello, I frequently do functions where I take a picture on my Canon 50D and using the included USB cable connected to a Canon printer, print the pic right away. Is there a way for me to print to mutliple Canon printers from one Canon camera, say via ...
I am looking for a rear feed printer that will handle 80 lb cardstock. I bought a Canon PIXMA MX 452 and it just doesn't cut it. Anyone have any ideas?
I do a lot of greeting card printing and, as card stock is fairly heavy, want to minimize the feed path of the stock through the machine. I have been using an PIXMA iP4500 with rear vertical feed for several years but I now need a capable replacement...
Bought the LIDE210 scanner, and while it initially worked fine, I got some settings messed up and couldn't figure out how to correct them, even with the on screen manual. So I uninstalled and reinstalled, but same issue. I've uninstalled again, and w...
I have a canon mg2100 series printer. I print shipping labels and use black ink. I ran out and changed the cartridge, now the text is faded looking and I can't read major parts of the label. I did the cleaning print head under control panel and it di...
ocr software for pix ma mg4120
My cartridges all show plentiful ink in Supply Levels, but test page shows only cyan and magenta, nothing at all for the other three, and when I print a document, the paper comes out without a mark on it. Print head adjustment failed twice, and the s...
Hicannot get printer to print PC shows "An error occurred while printing" on PC screen nothing showing on printer all looks fineToubleshooted no problems on printer test print worked .Had YAC (yet another cleaner) installed by Microsoft but that was...
Hi, When scanning, e.g., a letter size document - is there anyway to set up the scanner so that is scans the entire area of the glas? - i.e., in effect adding white space below where the document ends. Regards,Klas
Installed printer yesterday and it appeared to work OK.Today when I attempt to print the document just sits in the Queue with the status of "Printing".Restarting the document doesn't work.If I print from another computer running XP it works perfectly...
Helo My Dear Friends, I have a canon printer, The printer Model number is PIXMA IP 1800. When put any print will come a error message. That is THE INK ABSORBER IS FULL... can you help me..... Advanced thanks for valued your replies...Thank youBest R...
wind7(64) and 922 printer, scanner driver does not install, printer works, no error msg generated while trying toload scanner driver
| Subject | Author | Posted |
| 09-15-2026 11:48 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
