Desktop Inkjet Printers
My Canon MX892 will not print photos correctly.
Hi. my Canon MX892 has started having problems printing photos. Deep shadows are producing blue coloring, not black. Have done manual alighnment, multiple deep cleanings (causing ink supply to dwindle) but no improvement. Here is a sample of the prin...
scrawler by Apprentice
  • 6930 Views
  • 2 replies
Resolved! Doe Not Print
I have a Canon MX920 printer.  Recently reinstalled drivers.  I replaced a Canon ink cartridge with a "knock-off" which was instantly recognized.  All ink levels look good on the printer read-out.  Documents are blank when printing function is comple...
rosie46 by Apprentice
  • 3434 Views
canon mx715 error u052
hello, i seem to be having problems with my printer.at first it was the error code B200 which i fixed by lifting the cover and letting the carriage go past halfway and then closing the cover. i had to do this twice. it printed once then started throw...
talik719 by Apprentice
  • 5053 Views
  • 2 replies
Resolved! iP8720 will not print PDF files
My iP8720 will not print PDF files. It doesn't matter whether the file was created in Acrobat 8 Pro, Word, WordPerfect. It doesn't matter if the PDF contains images or just text. It does print files from Word and WordPerfect, as well as Photoshop, et...
clarowl by Apprentice
  • 4897 Views
  • 3 replies
ip4700 won't print correcting from the web
I'm hooked on the ip4700.  I've had two that both eventually died (they had heavy use). I bought a used one on eBay and it works just fine for some things -printing photos, artwork, etc.  BUT it won't print correctly from the web!  If I try to print ...
shaley1 by Apprentice
  • 3379 Views
MX890 stopped putting ink on paper - then died
I was away from home for 4 weeks.  The MX890 printer was left with power on for that time.  On return I tried to print a page and the printer printed a stored fax page first, then a blank sheet of paper. All ink reservoirs are full.  I tried to print...
Resolved! MX710 - I can print but I cannot scan
I just got a new Mac and cannot figure out how to set up scanning.  I am using MP Navigator EX to scan and it does not recognize the scanner.  Wireless printing is working just fine though.   In the Printers/Scanners tab, it shows the Canon MX710, bu...
