Desktop Inkjet Printers
alarm lamp solid
I bought my daughter a mg2920 last year for collage.  I bought her some ink to start off this year. She said about middle of last year the alarm lamp was solid and she hasnt used it since then.  I now have her printer and before I buy a new one, is t...
ddurden by Apprentice
  • 9684 Views
  • 3 replies
mg6120 grayscale
I am on a macbook os x 10.10.5 with a mg6120 printer.  I am trying to set up a default grayscale print option.  The old way of going under textedit- print- drop down textedit doesn't work because the drop down menu isn't there. I've exhausted my abil...
Nikipetz by Apprentice
  • 4670 Views
Pixma MX495
Hello how can i reset to the factory settings?And to connect wirelessly,i must setup the install program from the CD first,or i must start from the printer menu first,and install the software after that?Thank you
osfpgk7 by Apprentice
  • 4708 Views
  • 0 replies
print head incorrect
I have a MG5520 printer that gives an error message of "type of print head is incorrect", support code 1403.  It is not that old of a printer and I do not use it that often. Any suggestions?
My MP495 won't print, says it's offline.
The MP495 won't print, says it's offline. I've been trouble shooting over an hour, re-booted, re-booted the router, shut everything down, waited, etc., I've re-loaded the driver. Please help, I need this!!! Thank you.
Amybeth by Apprentice
  • 6185 Views
Canon AC Adapter K30323 6 connector pins
For K30323 I know pin 1 is the voltage, pin 3 is the ground. Can someone tell me what pins 2,4,5 and 6 are? On my MX-870 I get a B200 error. The problem may be the printhead but I want to measure the voltage on the 6 pin connector to verify the AC Ad...
waldo by Contributor
  • 4954 Views
  • 2 replies
