Where will I found the scanner lock on the Pixma MG6320 printer?
set231
Hello,.....Where will I found the scanner lock on the Pixma MG6320 printer?
Ramona
Hi set231,
The PIXMA MG6320 does not have a scanner lock switch.  If you are trying to secure the printer for transport, please follow these steps:
1.  Turn the machine off.
2.  Confirm that the POWER lamp is off and unplug the machine.  Please do not unplug the machine while the POWER lamp is lit or flashing white, as it may cause malfunction or damage to the machine, making the machine unable to print.
3.  Retract the paper output support, then close the paper output tray gently.  The output tray extension is retracted automatically when the paper output tray is closed.
4.  Disconnect the printer cable from the computer and from the machine, then disconnect the power plug from the machine.
5.  Use adhesive tape to secure all the covers on the machine to keep them from opening during transportation.  Then pack the machine in the plastic bag.  Attach the protective material to the machine when packing the machine in the box.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
1 REPLY 1
Ramona
Hi set231,
Friends and Family
