Scanning to PDF to my Cannon MX310 is not an option I can choose from... ONLY TIF And Jpeg...
Scanning to PDF to my Cannon MX310 is not an option I can choose from... ONLY TIF And Jpeg... How do I get PDF as an option.
new pixma mx922, windows 10, can't find download for scanning utility IJ network scanner selector ex
my printer is about 2 years old, i have only used it about 3 times, and not used in about 6 months or longeri tried to use it today and it will not turn on, i have never had any probelms beforeit will just not power up, i checked the plug, i switched...
Hi,I got my MacBook Pro (brand new) to see my Canon wireless printer, but when I send something to print, it tells me the printer is offline,when it isn't. I can print from one of my PC laptops, but not from the Mac. Any ideas? Julie
Hello, I have MP145 and i had to change the catridges recently because i got stuck with E5 error.i bought orignal canon PG830 black catridge and a duplicate CL831 catridge.am still getting E5 with color ink led glowing. please let me know on how to ...
Hello: when the iP4000 works properly it's really good but for some unknown reason has a tendency to fail frequently possibly due to faulty printhead design. The printhead was replaced abt 100 pix ago and worked well until recently when ink cartridge...
Hello all, I did a clean install of Windows 10 Pro (64 bit) and I have a Pixma MX-870 which I use wirelessly. It and its software were working perfectly in Windows 8.1 Anyway, I downloaded the latest driver install and when I run it it begins and the...
mg6250 scanner is not working message is: set the pc to start scanning
Why do scans on my MX870 and using the ADF have a grey coloured vertical line on the right hand side of the image, but do not have the line when I use the Platen scan facility? I have read other posts with the same problem and it has been suggested t...
I am getting this error whenever I am trying to Scan and Send documents.Are there any solutions to this?It was working perfectly a week ago.Thanks!
Anyone else having problems with feeding of photo paper from cassette 1 (upper)? I'm using glossy paper, 105g/sq m, cut to approximately 4" x 6" size, loaded face down neatly stacked against guides, about 8 sheets at a time. The printer will try to f...
I recently purchased the MG6800 and every time i try to print something from my mac it takes forever or doesn't work... it states the "printer isn't responding", or gets hung up on "connecting to printer"... eventually it works but i have to repeat t...
CAN SOMEONE WALKMETHRUSETUP PLEASE
I am using a Pixma MG3222. Print is very small, no matter if I print from the Web, PDF or a document using any of the iMac apps. Also, the Quick Menu does not show any functions in the Print or Manual & Device Information sections. This problem is o...
My Pixma 8120B prints everything too small. How do I adjust the print size please?
| Subject | Author | Posted |
| 09-15-2026 11:48 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
