03-15-2022 08:09 AM - last edited on 01-28-2024 03:23 PM by Kristoff
Hi there,
I recently bought the Canon LiDE 400 scanner as the resolution goes up to 4800. I need the maximum resolution as I want to blow up some antique hand painted artworks which are tiny. I have tried downloading the IJ scan utility software and changing the settings in drivers to allow large image scanning (found this in a previous post) but the resolution is still fixed at 600dpi. I am on a macbook pro. Is there another way and why can i not scan at the full resolution?
Thanks
04-25-2024 08:58 AM
I have the same issue. The maximum resolution I can select for the LIDE 400 is 600dpi.
I tried both with the Windows provided drivers, and with
Windows 11 [Version 10.0.22631.3155]
Maximum I can set in ScanGear is still 600dpi
Windows Scan app shows 600dpi max
GIMP TWAIN scanning app does not allow setting more than 600dpi
Scanner properties shows 4800x4800dpi optical resolution, but I can never set this to be enabled.
I also tried "enabling large image scans" but that didn't improve anything.
04-25-2024 12:46 PM
To go above 600DPI, you have to use Canon's Scangear. I see in your screenshots you are not using Scangear. In the first picture, you're using Photo Scan. And in the second picture, you're using Windows Scan. In order to get to 4800 DPI, you have to use ScanGear. you have to go to the settings for ScanGear and select the checkbox for "Enable large image scans". Once the setting is saved, go to ScanGear to scan the image. TYPE 4800 into the resolution box (don't use the dropdown arrow). Set max scan to 6.7"x9.2". YOU CANNOT GET 4800DPI WITH AUTO SCAN, DOCUMENT SCAN, PHOTO SCAN, OCR SCAN, STITCH (at least from what I can tell).
05-14-2024 03:34 AM
Hi, I have this problem too. I did the said solution and got the following warning.
05-14-2024 12:43 PM
did you check the box for "Enable large image scans".
05-16-2024 12:51 AM
yes, i checked it.
05-19-2024 02:00 PM
you need to lower the output resolution to 170mm x 233 mm. the input can be the full size of the paper (as long as it fits on the glass). but the output maxes at 6.7"x9.2"
05-16-2024 12:54 AM
05-14-2024 06:04 AM - edited 05-15-2024 05:52 AM
I managed to finally scan with higher DPI, in this one ScanGear window (part of "Canon IJ Scan Utility" app SCANUTILITY.exe), but I had to disable thumbnails view mode like hejavad said.
Hint: the icon in the top left disables the thumbnails view mode!
But now there are still all kinds of limits that I wasn't aware of when buying the scanner:
There is no way to scan a full page at that resolution, which is annoying. My PC has 128GB RAM and every graphics program is 64bit. Why am I limited to 4GB maximum image size?
And why does it only work in this single app, can the driver not be adapted to work with any app?
05-14-2024 12:44 PM
I'm going to guess that the 4GB limit is because the programmers designed for FAT32. But it's only a guess.
05-15-2024 05:47 AM - edited 05-15-2024 06:09 AM
Probably not because jpeg or png compress the raw scan data quite a bit before it gets stored to disk but the limit is on uncompressed data. Frankly I don't care what the historical reason is from 25 years ago before Windows XP with NTFS was popular. I want it "fixed". The warning that 100MB scans can slow down my computer and the 4GB hard limit look archaic and it's a random limitation that I wasn't told about when buying the scanner.
