07-16-2026
10:17 PM
09:52 AM
I've just finished setting up a new Color imageCLASS MF665Cdw that I purchased in part because it had a 600dpi scanner. And indeed, I see that resolution in the Canon MF Scan Utility. But that resolution is absent from the device's eSCL scanner capabilities, so I can't seem to get 600dpi resolution from other scanning software.
Here's how I retrieve the capabilities, and a few excerpts showing the resolution is capped to 300:
curl -s http:// 192 . 168 . 50 . 49 : 80/eSCL/ScannerCapabilities
<scan:PlatenInputCaps>
<scan:MaxOpticalXResolution>300</scan:MaxOpticalXResolution>
<scan:MaxOpticalYResolution>300</scan:MaxOpticalYResolution>
<scan:AdfSimplexInputCaps>
<scan:AdfDuplexInputCaps>
How can I get 600dpi in eSCL?
[URL modified to deactivate it.]
07-21-2026 02:35 PM
I called Canon and learned that this is just the way it is, it's not considered a bug. Scanning in the (standard!) eSCL way is limited to 300dpi. This seems consumer-hostile to me. I feel that I should be getting the full scanner capabilities when using standards-based tools, not having the best dpi locked behind Canon's own software.
08-01-2026 10:37 PM
Agree completely! Just purchased the same model, and ran into the same issue. Shame on Canon, but I'm not surprised at all.
