Professional Photo Printers
ccanada by Administrator
  • 3126 Views
  • 0 replies
  • 1 likes
Power up issues with Canon Pro-100 printer
Reading through many other posts about this power up issue..seems to me like there is a manufacturing issue with so many similar complaints.  I have this issue and did contact live technical support.  They kept telling me I was "part of the Canon fam...
Paper stops Advancing Pro-1000
My newly purchased Pro-1000 Is not advancing the paper on the last inch of the print. It happens with different sized prints. Since the paper does not advance I get an ink buildup where the paper stops advancing. Any advice would be greatly appreciat...
imagePROGRAF PRO-1000 Replaceable Print Head
I always use only the printer manufacturer's ink with my printers.  Nevertheless, I've always eventually encountered clogged inkjet nozzles which would not clear no matter how many times the built in cleaning process was performed.I'm interested in t...
rodmo by Apprentice
  • 3302 Views
Pro-1000 mangles bottom of print
I've printed an A4 on a Foto Speed NST Bright White (315g) through the manual feed with great results.  The same print on Pearl Luster (290g) comes out mangled at the bottom.  The A4 settings are through Canon Professional Layout with the appropriate...
eburm by Apprentice
  • 1209 Views
  • 2 replies
Can you open the top of a PRO 200 printer?
I was trying to print and the paper kept tilting the the right when being fed through and jamming. I realized the right little white piece and spring that helps guide the paper had fallen off. I used tweezers to fish it out of the hole but now I can'...
IMG_5992 2.jpg Screen Shot 2022-09-11 at 3.25.49 PM.png Screen Shot 2022-09-11 at 3.27.42 PM.png
dmoy2527 by Contributor
  • 1560 Views
