06-25-2014 03:32 PM - edited 06-26-2014 11:58 AM
My Pixma pro100 is 13 months old and suddenly will not power up. There are no unusual circumstances. Push the power button, & nothing!!! I've seen others that removed the power supply and re-installed as a fix, but that did nothing. Any other suggestions out there? The prints are absolutely beautiful, but to last only 13 months of light use is unacceptable. Please let me know if you have any suggestions, thanks!!
01-25-2019 11:28 PM - edited 02-05-2019 03:21 PM
I had this problem as well, and called the technical support line at the number above. The tech support person said to do the following sequence below, which worked! She said it had to do with a power surge. I do have this plugged into the same outlet box as a laser printer but don't have much option here at work. She said to do the following:
1. Unplug the printer.
2. Briefly but firmly press the power button 10 times in a row.
3. Press and hold the power button for 10 seconds.
4. Plug in the printer. At this point I heard a "snap"/"pop."
5. Press the power button. You should be ok.
UPDATE: I had the problem again, and a new rep said to press it 15-20 times while unplugged. Also, she said to wait an entire minute before plugging it in. That worked! She said it should be plugged directly into the wall, not into a power strip or extension cord. I'm not sure I'm going to be able to pull that one off in my 1983-built office!
12-07-2020 05:29 AM
Had the same problem, pixma pro 100s not starting. Nothing would do.. I tried the button pushing, and the waiting but nothing happened. I didn t know what the problem was and didn t want to buy a new 30€ power block for nothing if it wasn t the problem. I sent it to canon for free and they asked 200€ for the repair and it was, a power block malfunction...they changed the printing head too eventhough Im quite sur it was in working condition as I Print the printhead unclogging patterns regularily and it was all fine.
I wasted 170€ , I really though there was no reason for the powerblock to break but it seems that the quality is very bad and it tend to break after few years... next time Ill know.
You can find a new Power Supply Adaptateur on ebay for 30 euros and it is really easy to change, I suggest trying that before sending it to repair.
12-08-2020 05:06 PM
I bought a refurbished power supply but it didn't work. Better to buy a new printer when they discount them heavily at Christmas.
04-05-2021 11:25 PM
Hello! I have the same problem too but the repairer said that the power was dettached inside and I don't understand it. I have no background in circuits. Can you help me?
04-06-2021 03:37 AM
the powerblock is easily detachable, maybe that s what the repairer meant, maybe you just need to plug it back.
There is videos on youtube to help :
/watch?v=6iFvkevGgEk
04-07-2021 09:57 PM
07-04-2023 11:17 AM
today I called Canon. "Printer needs to be replaced." 2 years and needs to be replaced. NEVER AGAIN. $900 every 2 years? i don't think so.
07-04-2023 11:26 AM
Did you go through the strange procedure?
07-04-2023 11:39 AM
I went through the procedure that he told me to do. I unplugged it plugged it back in, hit the power button and he said it was dead
07-04-2023 11:41 AM
07-04-2023 11:44 AM
I also took out the power module and I tested it with my VOM and there is power coming out of it. SO it's the printer.
