Point & Shoot Digital Cameras
SX50 HS with Speedlite 430 EX II
I'm trying to use a Speedlite 430 EX II with my SX 50 HS, but the Assist Beam of the flash doesn't seem to work. The camera's Assist Beam works correctly, the flash fires, but the Speedlite's Assist Beam doesn't. Is it normal? Thank you!
Help choosing memory card for SX50 HS.
As far as I understand, UHS-I cards are useless unless you want to run at 10Mb/s. There are lots of cheap SDXC memory cards out there but they are slow. Can you recommend the fastest card at 64Gb or 128Gb that is compatible with the camera, preferabl...
csw1 by Apprentice
  • 20685 Views
  • 4 replies
Using higher wh battery in canon Elph 100hs
 I recently ordered a new battery charger for my Canon Powershot ELPH 100 HS because my old one was taken when the bookbag it was in was stolen. The new battery charger is called "Digital Video Battery Compact Travel Charger" and has an AC input and ...
myero by Apprentice
  • 4151 Views
Flash _Canon A1400
How do I get the camera A1400 to go to "Flash On". i.e so it will flash in daylight. Some call it " flash fill" other call it  "forced flash" The manual refers to this mode, but I can't get it to work. It only gives me :Auto" or "Off" not "On" This i...
