PowerShot G7 X Mark II screen shows too much information
misty29
 Hi!! I’m a newbie can someone help me with this? When i open my preview it shows up so much details.. and i can’t see my pictures clearly like before. How can I go back to how it used to be? Thankyou!
p4pictures
Press the lower part of the round circular ring on the back of the camera. It has the word INFO inside the ring. For each press of the lower section of the ring the camera will cycle through the different display options, including one with only the picture and the one you showed above.
Brian
4 REPLIES 4
I recommend that you reset the camera to defaults and see if the behavior / issue persists.
stevet1
misty29,
If you go to page 112 of your manual, it will tell you how to change your display options.
Steve Thomas
p4pictures
Brian
It’s back to how it used to be now! Thanks a lot Sir! 😁
