powershot a2500 buttons
digishan12
the buttons of my canon powershot a2500 suddenly won’t work but sometimes it does the only button that is always working is when viewing the images and the shutter button can someone help me
2 REPLIES 2
tracey258
It's likely that dirt or debris is affecting the buttons, or there might be a loose internal connection. Try cleaning around the buttons with compressed air or a soft brush after turning off the camera and removing the battery. You can also try resetting the camera to factory settings. If the problem persists, it's likely a hardware issue, and you'll need to consider professional repair in Vadodara or a replacement camera. The playback and shutter buttons might be working due to different internal connections or more frequent use.
Ron
Moderator
Moderator
Hi digishan12,
Thanks for letting us know what Canon product you've got. The PowerShot A2500 is an older model which we have retired. While that means that Canon USA no longer offers direct support for it, your friends here in the Canon Community are welcome to offer suggestions!
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
