Resolved! Can my Canon T5 fit a 64GB memory card?
Hi!I have a Canon Rebel EOS T5. I want know if my camera can accept a 64GB memory card of SanDisk Ultra 64 GB Class 10 SDXC UHS-1 until 48 MB/s. Please help me!
the flash model is triopo tr-988 it work grate with my old 7d ' but with the new 6d mk2 only laser marker dosn't work /i alredy changed the settings on camera to "unable" on te laser spot assistent..
Let us know what you think
i'm having a bit of a headache right now: exposure/aperture simulation wont show in viewfinder (but is working absolutely fine on lcd liveview screen). i do see all the info in viewfinder (i also see the sensor «reading» the exposure/light when i poi...
Hello,So I have the Canon EOS 200D, and have for quite a while now. It has been working fantastically well up until now, it focuses and does the focus beep, but won't take a photo, that is not all that it does, when you switch it on it takes a photo ...
Is there a way to fix my Sigma 70-300mm lens. when I put it on my Rebel XTI I get an error 99? There is a guy in Canada that says he has a re-chip for it, which requires opening the lens, cutting and soldering on the inside.
Hello All, i was hoping to get advise on the reason my images are being ruined. I use a 5D mark 2, and my memory cards are Lexar professional 1066X. not all the images result in this but i good amount do. when i look at the images in the folders ive ...
noisy https://drive.google.com/open?id=1hDbBqIZwG-27lxRQ7IiKiNzE_xgoCmox
I may just have a defective camera. Literally started it up this morning - followed all directions, including suggestions on pressing Info button repeatedly to ensure that it wasn't on LCD Off, cleaned rubber eye piece and made sure it was in place. ...
I got one for my M100 at Best Buy and it is much sharper than my kit 15-45mm. I was going to get one of the older EF lenses and use my adapter, but this lens is so small, that it is easy to pocket the whole deal.
Will using the 'ef-eos m' adapter to mount ef or ef-s lenses on a M50 block of affect the built in flash? I ask this as they are generally bigger than m series lenses.
Is it possible to configure the Rebel T6 to upload photos directly to a Dropbox folder? If so, how can I configure the settings?
Hi all,I have my canon t6i connected to my Mac with a usb cord. I pull up the EOS Utility and I cannot even click on remote shooting. It’s grayed out and isn’t clickable. Is there a camera or Mac Book Air setting I need to change to get this to work?...
I have a Canon SL1. I am having trouble with the AV mode. There is a long delay once I press the shutter button and then the picture never appears. It is not on self-timer and is set to F8?
I cannot connect the T6 wirelessly to my laptop (Windows10) using the EOS utility. I can connect via USB. I can also connect the T6 to my smartphone wirelessly. The EOS utility shows the EOS pairing screen, but it is blank when I click on the "pai...
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM | ||
| 12-14-2025 10:25 PM |
