EOS RP Audio/Video out of sync
Let me try and explain. EOS RP set to Movie. USBC to my PC. Using OBS, there is a slight sync issue where the video is behind the audio. Any suggestion to add a delay or something to the audio? thx!
i had my r6 mk2 * button set for spot, one shot, no tracking, no servo old school style. Somehow that changed and i discovered a few things while trying to get the setting back. When the *button is set to Spot the camera will not focus. AT ALL. A...
Got my wife a 5D Mark IV and Nauticam Housing for UW photography. Problem with Quick Control menu My wife shot with a 5D Mark II for the last decade, and is great with it...Now with the Mark IV, we NEED the quick control menu to "simulate" the same c...
Hi, just had a strange situation where after turning on the camera and shooting in bright sunlight and then also indoors, my pictures are recording with a dark band from top to bottom, almost like the shutter has not fully opened/closed correctly. Us...
I purchased a slightly used 5DS R, needed a secondary for my 5D MIII. Everything worked great, viewfinder displayed all AF points, leveler, etc. I shot with it for a test run and it was fine. Going through the settings I realized the firmware was out...
Going absolutely bonkers with this and there has to be an easy solution but I can't figure it out. What am I doing wrong? I want to be able to toggle Eye Detection on/off with one of the customizable buttons. Period. I've chosen the "AF On" button, a...
I have a new R10 that I can’t get to connect to my iPhone via WiFi, always says "Unable to join the network". When I go in my phone settings the R10 WiFi network doesn’t show up on phones (tried different phones) and laptop and even if I manually typ...
It's impossible to copy videos from a CF Express card to an SD card using "Image Copy". I didn't have any problem in R5, but I think the new foldering system in R5 M II causes this problem.
I recently replaced my old 5D Markii with a R5. I can’t get my Interfit S1 strobe to work with it. Am I missing something in the settings or is it even compatible or do I need a different hot shoe remote. The pins on the two cameras hot shoes look th...
Subject: Firmware Limitations with Canon R3 / R5C and EL-1 Flash – Feedback RequestDear Canon Global Support Team,I am a professional photographer using the Canon R3 and Canon R5C camera bodies along with the Canon EL-1 Speedlite flash. While I am ge...
Hi guys I have been a nature photographer for about 5 years and I have been using my Canon Eos 7D for about 2 to 3 year's and for some reason while I was photographing birds it suddenly just showed a Error 20 on the screen and then the shutter didn'...
A recent issue with my camera has me stumped Body: R5 mk1 + EF adapter Issue seen with EF 16-35 F4L mk3, EF 24-70 f2.8L mk2 and 100-400 f4.5-5.6L mk2At the wider zoom end of these lenses I cannot get the camera to focus at distant objects. Only by in...
My canon eos 4000d has suddenly ceased to turn on. Ive tried multiple batteries within in. But with no luck. No damage had been made prior.
I am having issues taking photos with my Canon EOS Rebel T100 / 4000D camera only bought about 6 months ago. It was working fine until after I did not use it for about a month or two. It is not focusing, and does not take photos unless on MF mode. Sc...
Hey everyone,I've been using the Canon EOS R6, and I primarily shoot in aperture priority mode. I have a question regarding the minimum shutter speed setting. I want my minimum shutter speed to not go below 1/250 when I'm shooting in aperture priorit...
| Subject | Author | Posted |
| 09-20-2026 03:10 PM | ||
| 09-09-2026 07:25 PM | ||
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM |
