10-12-2024
03:45 PM
07:59 AM
James_C
Hi, Has anyone had the temp warning while taking pictures with the R5 mark 2? I notice the temp warning coming on while taking pictures. I do have the battery grip with the fan and it will reduce the heat, but I am only taking pictures. I do notice that it takes longer to see the temp warning if i do not have the grip on ( maybe because the ventilation holes on the bottom are not covered). Last i did call B&H tech support and they mention i should be using the Type B card not the type 2 and I still see the temp warning symbol. Any suggestions would be appreciated. Thanks
10-12-2024 04:29 PM
Tell us about your shooting conditions. How can I reproduce this error? How long does it take for the warning to appear?
10-14-2024 05:01 PM
Hi Waddizzle,
i have seen the high temp warning in various conditions, but most recently 64 degrees outside ( sunny outside), using CF card, Mechanical shutter, battery grip ( with the fan but not on). I have a guess that when i don't run the fan on the grip it blocks the ventilation holes on the bottom of the camera. I will have another shoot on thursday and will try without the batter grip. also the warning comes on at various times example last time was after 64 photos and another time inside a gym after 180 photos ( but i was in electronic shutter mode shooting 30 fps). Thanks for your help
10-14-2024 07:53 PM
@leestuar1970 wrote:
Hi Waddizzle,
Thanks, for the update!
If you. Have the grip with the fan, then I think you should turn on the fan. You’re probably correct to conclude that the grip could be blocking the ventilation holes in the main body.
It is not clear how much time elapses before you begin to see heat warnings. How many minutes have elapsed to take 64 photos? What are you doing between shots? Does the camera ever go to sleep between your shots.
Lastly, are you shooting stills, videos, or a combination of both? How many minutes does it take to capture 180 shots at 30 fps? That sounds like a little more than 6 seconds, to me. I am sure it takes you more time than that, though.
How many minutes elapse before you see the warnings?
Are you shooting from a tripod with the rear display on between shots?
I still do not know how to recreate your issue.
10-15-2024 06:48 AM
its really is random ( Hot and cold climate conditions) time when I have seen the warning indicator come on. the last time I saw the heat indicator was after shooting 64 shots at within 30 mins. I left the camera on, but I didn't let it go to sleep ( I was waiting for action). lastly I only take picture and no video. I only shoot handheld and I do have my rear display on with it turning off when I look through the EVF.( also the Display and EVF are default brightness). Do you have the grip with the Fan? Thank you for your response
04-28-2025 06:38 PM
Did you resolve this issue? I have begun having overheating issues since the last firmware update. I do not see the warning indicator come on--I just get the black screen with the overheating/shutting down message.
11-25-2025 02:09 AM
I know this is an older question but I am pretty sure I have your answer. And it's the same as the original R5.
When you are shooting images your camera will get warm/hot. But you'll be fine with pictures. The warning indicator is showing what would happen if you switch over to video. Your camera would be getting hot for that. The fix is actually easy. Switch to video and make sure the video mode is one that won't have any over heating issues. Then the warning indicator will dissappear from the photo side because the camera knows if you switch to video you wont have an issue.
For example, if you switch to video and it's in 4k 120, then during photos the temp indicator will come on a lot. Because 4k 120 overheats faster than others.
Put your video mode in full HD and the indicator will never come on in photos. Because if you switch to video you won't overheat the camera.
Hope that helps.
11-28-2025 09:52 AM
Lots of good feedback in the replies. What follows is not an ideal solution for shooting stills, but perhaps a useful bit of info. I have noticed that when shooting video, if I have the display folded in to the closed position (with either the cover facing out or the video display,) the camera will overheat faster. If the display is flipped out to the side, the camera takes longer to overheat. I’ve been told that the display itself doesn’t generate much heat, but being folded in the closed position, it blocks the radiant dispersion of heat from the body.
01-06-2026 05:02 PM
interesting, it only shows this icon in auto mode, and its right away as soon as I turn the camera on, i hve not take any photos to get it hot, the camera is room temp, and no fan grip that will be here tomorrow
01-06-2026 05:59 PM
Why write that nonsense?
