11-15-2015 03:55 PM
I definitely had the right image quality selected when shooting RAW + L, even the LCD says it is for each preview, the info button avails the correct image quality. However, when I import to my computer and Lightroom, the only pictures I see a .jpg and not CR2 at all. Isn't there suppost to be 2 files for each shot anyway? The manual says they should be in the same folder.
11-17-2015 05:29 PM
Here's fix for your RAW in Photos issue.
11-17-2015 05:35 PM
Photos and Lightroom both work perfectly with RAW files, so unless you have a specific need for a straight out of camera RAW file there's no need to shoot RAW+L.
11-17-2015 06:42 PM - edited 11-17-2015 06:43 PM
There are some issues wih El Capitan and Lightroom, but they are not related to what you are doing. I am using LR 6.2 on my MacBook with El Capitan with no problems.
I also have no problems with my Wacom Intuos (not the Pro version).
Here we go:
1. connect your camera or insert SD card in card reader. If Photos opens (and you don't want it to) toggle the selector in upper left hand corner of header.
2. Quit Photos and eject device. Reconnect device; nothing should happen. Go to Apps and select Image Capture. Select the card, and at bottom of that column will be an arrow icon. Use that to select what you want to happen when that device is connected.
As I said earlier, to Apple a reformatted card is a new device. Not a major deal, but if you want to avaoid the hassle delete the files from the card rather than reformatting (until you need to).
11-15-2015 06:11 PM
What camera are you using? I assume you're aware that if it's a 5D Mk III, the two images don't even have to go on the same card.
11-15-2015 06:15 PM
@RobertTheFat wrote:What camera are you using? I assume you're aware that if it's a 5D Mk III, the two images don't even have to go on the same card.
I was *just* thinking this... while I very rarely shoot both RAW + JPEG on my 5D III but if I do I send them to different memory cards.
11-17-2015 01:23 PM
EOS Rebel SL1 w/ 18-55 STM. It's not recording RAW. All I know is that I have shot using the same image quality before and ended up having cr2 files able to be imported both to the computer and to Lightroom .... I don't have another memory card.
11-15-2015 07:11 PM
The RAW+L option is for Rebels. Single card.
11-17-2015 01:12 PM
11-15-2015 07:18 PM - edited 11-15-2015 09:32 PM
Are you using Lightroom to import images? If you go directly to the folder with the images in Windows Explorer or Mac Finder are there RAW and JPEG files there?
Since you said you're using Lightroom, is the version of Camera Raw compatible with your camera model?
11-16-2015 09:33 AM
In the General Prefference settings in LR, the default is to import just one file. The raw one. The jpg is ignored unless you tell LR to import it too as a seperate file. If you do you will get two files otherwise just one. IMHO, I see no reason to import the jpg as appearently Adobe does, also. But I never shoot raw + jpg anyway. Why? In the very rare times I want just a jpg, that is what I shoot.
11-17-2015 01:31 PM
The issue is that the camera isn't not recording RAW even though RAW + L image quality is selected and the info in playback mode says that the picture is. I would have expected to be able to preview 2 of each kind for each and every shot I took. There simply is only one available to be imported to the computer and it's a jpg not cr2.
11-17-2015 01:49 PM
The camera won't "shoot" a JPEG. It records all images as RAW and will process the data in camera to create and save the JPEG. If you select one of the JPEG settings the RAW file is discarded and not saved to the card. If you shoot RAW the JPEG creation process is bypased. In RAW+L the camera saves the RAW and then processes and saves a L JPEG.
I can't envision how the RAW isn't on the card. Can you access the card directly and see what's on it. I just switched my camera to RAW+L and took on image.
If your issue is that you can't preview a RAW and L on the camera, that is not a problem. You never really see a RAW file on the camera. Even if you shoot RAW only the camera shows a processed JPEG from the RAW.
