11-15-2015 03:55 PM
I definitely had the right image quality selected when shooting RAW + L, even the LCD says it is for each preview, the info button avails the correct image quality. However, when I import to my computer and Lightroom, the only pictures I see a .jpg and not CR2 at all. Isn't there suppost to be 2 files for each shot anyway? The manual says they should be in the same folder.
11-17-2015 05:29 PM
Here's fix for your RAW in Photos issue.
11-17-2015 05:35 PM
Photos and Lightroom both work perfectly with RAW files, so unless you have a specific need for a straight out of camera RAW file there's no need to shoot RAW+L.
11-17-2015 06:42 PM - edited 11-17-2015 06:43 PM
There are some issues wih El Capitan and Lightroom, but they are not related to what you are doing. I am using LR 6.2 on my MacBook with El Capitan with no problems.
I also have no problems with my Wacom Intuos (not the Pro version).
Here we go:
1. connect your camera or insert SD card in card reader. If Photos opens (and you don't want it to) toggle the selector in upper left hand corner of header.
2. Quit Photos and eject device. Reconnect device; nothing should happen. Go to Apps and select Image Capture. Select the card, and at bottom of that column will be an arrow icon. Use that to select what you want to happen when that device is connected.
As I said earlier, to Apple a reformatted card is a new device. Not a major deal, but if you want to avaoid the hassle delete the files from the card rather than reformatting (until you need to).
11-17-2015 04:37 PM
jthoffman it deosn't sound like what you are trying to tell him is correct for what he stated.
"The issue is that the camera isn't not (?) recording RAW even though RAW + L image quality is selected ..."
If this is the case, than there should be two files. But LR will not import both unless you tell it to.
I don't know exactly what he is trying to say with this, "RAW + L on the LCD is not the FILE EXTENSION"
There seems to be a grammar issue here. Anyway the LCD, on the camera? Maybe I am not understanding what he wants to know how to do.
11-17-2015 05:02 PM
I'm almost certain the problem is with my computer's operating system the new OS X, El Capitan. Drivers are going berzerk for so many applications that I've decided to downgrade to Yosemite which is the operating system I had before. The Adobe apps because don't work well with it, also my graphics tablet. Moreover, it wants only to connect the camera to its built-in app, Photos, which won't avail the CR2 files. I'm almost completely sure now that my camera did record RAW, it's just I wont get to see or work with those until I have the better operating system back again.
11-17-2015 05:03 PM
11-17-2015 05:06 PM
11-17-2015 05:08 PM
11-17-2015 05:12 PM
I am going to let you have this one! You are the Mac expert.
11-17-2015 05:19 PM
That's fantastic that you're willing to look into it! I do hope Adobe and Apple will get together to figure out the conflicts between the two. I know that Apple is aware of it. I spoke with them yesterday.
11-17-2015 05:20 PM
11-17-2015 05:29 PM
11-17-2015 05:35 PM
