Desktop Inkjet Printers
i9900 isn't printing "reds"
I am having trouble with my i990 printer.  As a test, I just printed a colour wheel and for some reason, my i9900 printer will not print red properly, if at all.  Yes, the red ink cartridge is full.  It seems to print blues and yellows properly. I am...
Double sided printing
Can anyone please help? I use Mac OS El Capitan and a Pixma iP8750 A3 printer.I have a couple of very frustrating issues. !) How do you enable double sided printing ( I believe it is also termed Duplex printing)? I have read in the manual that the pr...
Knysa by Apprentice
  • 3973 Views
printer cannot recognize ink cartridge
I'm using a canon pixma ip 2770. I just refilled the colored cartridge and the problem is that when I inserted it again and tried to print a document it suddenly cannot recognize both cartridges. But it can when only one cartridge is inserted. What c...
vanc by Apprentice
  • 5555 Views
  • 2 replies
printer not connecting to laptop
My mg 2550 connected to laptop via usb cable has been working fine but suddenly stopped working as it does not recognise the connection. I have tried 2 other laptops but it does now work with any of them !I uninstalled the printer on one of the lapto...
stonover by Apprentice
  • 3638 Views
iP7250 printing shadow/double text
Hello , my iP7250 started printing double shadow text , I tried to clean the encoder strip , manualy calibrate head alignment, and  I cleaned printing head completely, seems nothing is working .  Does somebody have advice or a same problem? Thank you...
rinma_91 by Apprentice
  • 2730 Views
Print sort Canon MX420
Is there a setting I can uses to print sort? When printing the first page is at the bottom stack. Every packet I print I have to go back and resort my packet. Sometime I would have pack of 40 pages and have to resort the order of pages. CanonPixma MX...
Error code 1403
My Canon  MG 5420 was working fine until I purchased a new computer and router,  now I get Error code 1403, Print Head Incorrect.   I replaced my ink cartridges.  Unplugged and plugged back up but I'm still gettingthe same message.  I have no clue ho...
My Image Garden
I wish to copy pictures in My Image Garden to a another folder in my computer.To do this I am highlighting(selecting) the pictures in MIG and the EDIT COPY.    When I go to the folder to which I want to down load the pictures into the Paste symbol is...
ts6020 usb
ok I may be crazy but can someone direct me to where the usb insert on the ts6020 is? the online manual is of no use
Scanning Issues
I purchased a Canon Pixma TS 9060 a week ago every is working fine except I cannot scan from the printer as a command comes up saying " set the PC to start scanning" - has anyone else had this issue rather frustrating - what to do ???
Shalom by Apprentice
  • 2650 Views
MF735Cdw interrupts incoming voice (not fax) calls
My MF735Cdw often (not always) attempts to 'receive' a fax by 'answering' a voice (i.e., non-fax)  call that is in progress, even when RX is set to "manual" or "answering machine." Something is triggering it to 'pick-up' the phone line, even when no ...
spanman by Apprentice
  • 3056 Views
Enable bi-directional support?
Having made no change that I am aware of to my MX 490, when I select the option for duplex printing in the dialog box, I have started getting the following popup message: "Cannot communicate with the printer.Turn Enable bi-directional support on in t...
doggod by Apprentice
  • 4383 Views
MG 3122 - scanner driver
I recently had to do a clean boot of Windows 10. No trouble printing from my Pixma MG 3122. But when I try to scan, I get the error that the scanner driver is not installed. I've tried installing 3 versions of the MP Navigator driver (EX 2.1, 3.1 and...
tmlarock by Apprentice
  • 5200 Views
