Desktop Inkjet Printers
MG5550 paper jam
I have a very(and new) annoying problem with my Canon MG5550 that has always caused issues. When I try to print something, anything, the feed is starting and when the paper reaches the roller that turns it to the printing side, it jams on the right s...
Canon MP530 printer missing lines
I have a Canon MP530 printer and the printed page is missing many pieces of the horizontal text. How can I resolve this? If I print photos the images come through just fine. This occurs if I'm printing from Word, a PDF, or a  webpage, so it doesn't s...
alohatac by Apprentice
  • 14615 Views
  • 6 replies
HELP NEEDED - Borderless printing on A4
Hello, I'm wondering if someone can help me out and give me some proper advice. Forgive me if I've gone totally the wrong way about this.I'm trying to print four A6 size postcards on one A4. I've designed the postcards in photoshop sized (width) 105m...
Canon MG2520
Text is coming out too large!  Won't fit the paper.  Just started doing this.  Tried to change setting but no help.  "Test" page comes out fine though.
joew55 by Contributor
  • 2597 Views
OCR option in scan and send
I have a Canon IR-adv C5051 that i'm trying to turn OCR on for scan and send. I've found the setting listed here for turning on searchable PDF http://local.nols.org/techsupport/printers/Canon5045/contents/adfunc_005aeb/func.html On my C5051 though th...
spete87 by Apprentice
  • 3050 Views
Canon Printer MG2520
Hi.  Newbie here.  When I print from different on-line sources to my printer, everything prints too large for the page. I'm getting about 75% of the text,   I did a test page print to check the printer and everything comes out fine. I tried the "fit ...
  • 2088 Views
  • 0 replies
Canon MG2950 scaling up plans
Hi Can anyone help please? I have scanned a copy of an instruction manual from an Airfix kit on my Canon MG2950 printer.I want to increase the size of the scan to the physical size of the kit so I can cut out the camoflauge pattern and use it as a pa...
Printer not Recognized on my Computer
I have a challenge recorgnising my Printer on my computer, i installed canon iP7240 and used it for some months then suddenly it stopped working i tried uninstalling and re-installing but it did'nt work i tried removing it from my device and then sea...
ifedee by Apprentice
  • 2373 Views
  • 0 replies
  • 1 likes
Resolved! G3200
I have a Prixma G3200 MegaTank printer. Recently it has started printing background images only - no text. Occassionally, text will be printed, however, its so faint that it is unreadable. Printing from a PC running Windows 10. Any help would be appr...
TS8020 Malfunction
Hello - my TS8020 printer is stuck on an error message on the screen that I can't seem to fix.  It reads "Ending....please wait a while."  I've unplugged the printer and left it off for several hours.  When powering back up, I can get one or two prin...
ewoller by Apprentice
  • 2671 Views
MG5240 head
Hello everyoneI have an Pixma MG5240 which was sleeping for a long while.I decide to service it. As you can guess, its head needed to be cleaned because black and yellow colors were terrible! After a lot of deep and normal head cleaning and using hea...
Ehsanr by Apprentice
  • 4072 Views
  • 5 replies
Error Code 1259 on brand new Canon TS8150
Help!  Have a brand new printer, which was working fine for a couple of weeks and now I can't get rid of error code 1259.  Taken paper tray out, emptied it, checked no paper stuck.  Turned off at mains, waited, turned on again.  Still the error code ...
Pixma TS3122
I installed this printer about a month ago, wirelessly, to two computers which sit side by side with the printer between them.  Everything prints just fine from one computer, but the other one gets the message that the printer is "off line" each time...
jusjudy by Apprentice
  • 4932 Views
  • 3 replies
Canon MP610 error 5100
Help!  My mp610 ran out of ink for the first time this week and I replaced it with genuine ink from staples.  A day or so after changing the cartiges I received an error message that hasn't gone away.I have restarted,replaced the ink againchecked for...
