Desktop Inkjet Printers
Resolved! PIXMA G3100 default setting
If you forget the administrator password you specified, initialize the printer to revert the password to the default setting.  how to do this =  revert the password to the default setting.   thanks very much
edxson by Contributor
  • 4222 Views
Unable setup MX922 due to printhead alignment
Just purchased a MX922 and have been unable to finish the setup process due to printhead alignment/nozzle issues.  I get to Step 3.8 to perform the Print Head Alignment  with the MP 101 paper andwhen the process runs the page is blank and I get an er...
MG5220
Hello I got a 5520 MG trying to print avery lables does any one know if thats possible thanks
Canon MG7120 scanner
I am operating on windows 10 on two laptops. On my oldest one, I was always able to scan with no problem, and now it has stopped. The message error I get is that it cannot communicate. Everything is properly connected. It does stay scanner is turned ...
Jwalwow by Apprentice
  • 4070 Views
  • 3 replies
Printing quality MX395 not okay
When printing with our MX395 the characters are partly in italic and a little bit blurred. We installed the latest driver from the canonsite, use Windows 10 and tried all the print quality varieties: draft, normal and drafts. What can we do about it?
Joepie by Apprentice
  • 3177 Views
MX920 won't print.
I have a similar problem with the MX920. My printer is connected thru a wi-fi router, and all the computers on the network, run Windows 7. The message I get is " Another computer is using the printer. The following status is the status of that comput...
error code 1300
i have an error code 1300 on my printer ts5100 i have removed paper checked every thing their is no paper jam but i stil have this code coming up on my panel what do i do to clear this.
PIXMA MG7720
Tried to set-up printer wirelessly to my Mac.  Couldn't achieve that so want to set it up to using a USB cable instead.  But the option to chose the USB cable no longer exists.  Any suggestions as to how I get out of the wireless setting to be able t...
artfesst by Apprentice
  • 3768 Views
  • 2 replies
Error B200 - What????????
I've got a PIXMA MG5320 printer and a "has incurred a B200 error" with the message to contact the service center.1st - what the is a B200 error?2nd - what service center? the ONLY numbers I can find are only good from 10:00 AM EST to 10:00 PM EST - N...
Resolved! TS6020 Legal Paper Problem
Have just bought this printer. Legal size document I want to copy can be put into the rear loader, and registered to use, BUT, the cassette cannot load legal size paper. So how can I copy the legal size?To repeat a common complaint - the manual is no...
nickbb by Apprentice
  • 7940 Views
  • 5 replies
