Desktop Inkjet Printers
MX922 status not connected
Hello,I have a Canon printer MX 922 showing not connected status and I'm not able to print wirelessly. On Windows devices and printer settings, it is showing that is connected to the network. Previously, everything was working fine. I cannot troubles...
bsy606 by Apprentice
  • 2175 Views
  • 0 replies
Pixma MX492-Scanner Defaults Macbook Pro
Hello, I have a Pixma MX 492 Printer/Scanner connected to a Macbook Pro. I would like to set up certain defaults upon opening the scanner feature. I would like my defaults for Document Feeder to automatically combine the pages into one file. As of no...
Unable to Scan without Sizing Error
Canon MX430 on my Mac OSX v 10.7.5 cannot print without at error with the text "Scanning cannot be performed unless the size is increased to 4 x 4 mm (0.16 x 0.16 inches).". I have changed the size but the error keeps popping up. How to fix?
Canon PIXMA MG 2100 Color Printing Problem
I have just purchased a MG 2100 and installed it on a HP Pavillon HTE Desktop.  The scanner works great!, the copier works great!  BUT when I try to print a color picture from AOL emails it won't print the picture unless it is in Black and White. Thi...
bobbysue by Apprentice
  • 41011 Views
  • 8 replies
  • 1 likes
Quick Menu Driver not installed
Hi Guys, Ive just purchased a MB2760 which is installed on my Widows 10 PC. The printer seems to be working fine but when the computer starts I get a small window popping up saying " A driver supporting quick menu is not installed" Any ideas please? ...
Canon Pixma MG5650 - PGBK not printing at all
Hello, I cannot get anything printed from the PGBK cartridge anymore. The cartridge is full, and I have just performed a full cleaning of the print heads (including a manual cleaning by removing the printheads from the printer and flushing them with ...
Canon Pixima IX6850 print issue
Hi all, I have a puzzling issue that's causing what little hair I have left to fall out, basically I've installed the drivers and softare for my Canon Pixima IX6850 and then proceeded to try and print using easy photo print ex but as I submit the pri...
Printer error code c000
hi I got a canon m922 printer and it keep coming up with error code c000 and the copy button is blinking and some orange light is on.  I ran out of ink and I replace them.  I turn everything off and unplugged the cord to the printer and to the outlet...
Dgcgpr12 by Apprentice
  • 27736 Views
  • 5 replies
a problem in my Canon pixma 2100
 Hello, I have a problem with my canon pixma MG 2100. The scaner works great. However it does not print at all. the paper stucked in the printer every time I try to print something and it always shows me that the paper is  jammed. It shows me that I ...
salnass1 by Apprentice
  • 2140 Views
  • 0 replies
E470 Wired Connection issue
Hi ,  i recently purchased pixma E470 printer and followed the installation set up.Wireless have no issue for the software menu.but WIRED connection will only work after 1st set up.after you turn off it will not work again as WIRED connection. im usi...
Resolved! Cannot create PDF with MG5720 printer
I own a Canon Pixma MG5720 printer, [Removed serial number per forum guidelines]. It is connected wirelessly to an HP laptop running Windows 10 Pro. Until very recently I was able to scan and make PDFs (via My Image Garden) using the above laptop and...
