Desktop Inkjet Printers
Canon Pixima IX6850 print issue
Hi all, I have a puzzling issue that's causing what little hair I have left to fall out, basically I've installed the drivers and softare for my Canon Pixima IX6850 and then proceeded to try and print using easy photo print ex but as I submit the pri...
Printer error code c000
hi I got a canon m922 printer and it keep coming up with error code c000 and the copy button is blinking and some orange light is on.  I ran out of ink and I replace them.  I turn everything off and unplugged the cord to the printer and to the outlet...
Dgcgpr12 by Apprentice
  • 27887 Views
  • 5 replies
a problem in my Canon pixma 2100
 Hello, I have a problem with my canon pixma MG 2100. The scaner works great. However it does not print at all. the paper stucked in the printer every time I try to print something and it always shows me that the paper is  jammed. It shows me that I ...
salnass1 by Apprentice
  • 2144 Views
  • 0 replies
E470 Wired Connection issue
Hi ,  i recently purchased pixma E470 printer and followed the installation set up.Wireless have no issue for the software menu.but WIRED connection will only work after 1st set up.after you turn off it will not work again as WIRED connection. im usi...
Resolved! Cannot create PDF with MG5720 printer
I own a Canon Pixma MG5720 printer, [Removed serial number per forum guidelines]. It is connected wirelessly to an HP laptop running Windows 10 Pro. Until very recently I was able to scan and make PDFs (via My Image Garden) using the above laptop and...
MG5520 will not turn on
I have had this printer for about a year and a half. It was turned off when I attempted to print today and will not turn on. I have checked the power supply and it is fine does anyone have a solution?
5defoes by Apprentice
  • 5675 Views
  • 2 replies
Resolved! Pixma mx892
my printer has refused to print on card stock today. Jams everytime . a piece of orange celluloid fell out also. I suspect it is a guide for cardstock leading edge. Am I buying a new printer?
Error message MG7120:
When scanning I receive this error message:Cannot display the scan result in My Image Garden because you do not have permission to access the folder in which the scan result is saved.Scan again with My Image Garden. How do I correct this and see my s...
jmc by Apprentice
  • 2616 Views
Resolved! Can't print 4x6 photo paper
I'm pulling my hair out. My blood pressure is through the roof.I put a piece of 4x6 glossy Canon photo paper in the rear paper feed and close the sliders in on the paper. I close the feed slot cover. The printer display tells me that I need to regist...
Just threads paper. But won't print
For some reason my printer won't print. It threads the paper, the cartridge makes it's usual sound. Then just spits the paper out and says "Check the printer for errors"... and thats it.It does the same for both Wi-Fi prints and cable connected print...
MP560 Error Message 5,202,63
Hi, all. Received this error message out of the blue today. I was attempting to scan a document. Action taken so far was to reboot both laptop and printer. Then I tried to reinstall the printer drivers, having downloaded them freshly from the Canon s...
