Desktop Inkjet Printers
Resolved! Very badly out of alignment
I have a Pixma MX452 that is very badly aligned. Automatic alignment does not correct it. Manual alignment gives me the black column F with all rectangles showing every other line a quarter inch left or right of the following line.It looks like:    X...
Canon MG2522 won't feed paper
Hello, i've had this printer for about a month and suddenly it just started to jam. It grabbed 1 piece and printed a slight amount of black on it then stopped pulling through, now it won't feed the paper through more than about an inch, i have tried ...
MG8220 Won't print from rear tray
I've been printing from the rear tray forever. Suddenly my Mac was no longer seeing the printer so I reinstalled the printer software. Now the printer prints from the main tray even when I choose rear tray. It just refuses to recongnize the rear tray...
seismic by Apprentice
  • 2071 Views
Printer Error HELP!!
I have a Cannon MG6620 and suddenly in the middle of printing a report it stopped and gives me this error message:The type of Print Head is incorrect install the correct print head"????I changed a couple of the Ink Carts and everything was working fi...
kayeD by Apprentice
  • 2689 Views
  • 3 replies
Cannon MG5520 print issue
My MG5520 will only print in black and yellow. I have cleaned and deep cleaned print nozzel. Aligned print heads and still just yellow. What can I do?
mtz by Apprentice
  • 1821 Views
Pixma iP8750 Photo printing issue.
I'm trying to print some 6x4 photo's on non cannon standard glossy paper.Started to get black smudges on the corners of prints, and now this is occuring:  Starts to print ok, then towards the rear of the print I get a clacking sound from printer.Ther...
Canon IP7220
I have a problem to print any picture or photo. For about 9-10 cm print is sharp and clear, after - blury. I printed test pages for Magenta, Cyan, Yellow and Black separately, same problem wih all of them.Any sugestion welcome
USB Connection Taking a Long Time
I am installing the driver that goes with my PIXMA TS3120 printer. When I get to the part where it finds the printer, the spinny wheel just keeps spinning. It says it will take "a while" but I have a feeling that something is not quite right, since i...
Liv27 by Apprentice
  • 3672 Views
MX885 no scanning option
Since last week I have been unable to scan - Windows 10 update I think.  I have removed all printer drivers and all Canon software.  I downloaded and installed drivers from Canon website and installed them.  I have downloaded and installed Quick Menu...
Orraman by Apprentice
  • 1505 Views
  • 0 replies
MX922 Support code 5011
I keep using scanner and locks up with code 5011.I follow instructions and does not work. I have to unplug printer and restart. It will then work for a while and get the same message. I called support and was told to push the on button 5 times while ...
