Desktop Inkjet Printers
Resolved! simple fixImageclass D550 printer/scanner squeals
I removed a jamed sheet of paper and since then I have had a squeal (or squeak?) for a couple of seconds after each page is printed.  The printed page also has a crease down the full length of the page about 3/4 inches from the left side, and a smear...
EJaasma by • Apprentice
  • 2720 Views
  • 2 replies
Installation PIXMA 450
My Canon Printer won't install because it keeps saying that the print spooler stopped and to restart it and retry, but that does nothing but stop the print spooler again. What's the problem?? What should I do?
Carts2 by • Apprentice
  • 1367 Views
PIXMA page torn inside printer
Is there ANY way to remove a partial page stuck inside the PIXMA that tore.  Was having the same misfeeding problems i am reading about here and tried to help a page get stsarted and it pulled it in and ate it.  Model is PIXMA 452
fjdb333 by • Apprentice
  • 1518 Views
  • 2 replies
MX522 half connected
Greetings and salutations! I brought an old personal printer into work because the "official" printer is too far away for quick print jobs. I've connected my laptop and the MX522 to my phone hotspot and my laptop sees the printer and prints to it. Ho...
elseedee by • Apprentice
  • 3287 Views
  • 4 replies
Canon Pixma MG2522
Hello, my name is Yenni Cabrera and I own a Canon printer model number: MG2522. I keep getting a yellow blinking light. I have cords set up perfectly fine. I am not sure exactly what is the problem. Please let me know what is the problem. I can be re...
yenni88 by • Apprentice
  • 1606 Views
An offset printing challenge for you!
Hi all, I'm having issues with a canon MG5350 printing images offset on small paper sizes. It works fine in A4, and the feed tray from the rear casette goes thin enough to take the 57x88 mm playing cards that I'm trying to print on, and it seems to f...
noorika by • Apprentice
  • 1179 Views
  • 0 replies
PIXMA MG7720 will not print 5x7 photos
My PIXMA MG7720 simply won't recognize the proper size in its tray. I have tried tray1, tray2. took one tray out. Here are error messages: The size or type of the paper loaded in cassette 1 is different from print settings. SUPPORT CODE 2111 Check wh...
Mick1 by • Apprentice
  • 9823 Views
  • 4 replies
Canon Pixma MG5450 Will not power up.
Hi Everyone, I am having issues with my Canon MG5450. It was working perfectly and then suddenly died, I did some googling and decided to replace the PSU. This made no difference. I also eventaully found a video describing how to test my old PSU and ...
hifly by • Apprentice
  • 1994 Views
Canon pixma
My printer only works when it wants. I constantly get an error saying to check printer for foreign objects.........
mrsvelez by • Apprentice
  • 1682 Views
Error 1000
Printing from an iMac, OS 10.13.6. My TS8020 has started to tell me it won't print because of Support Code 1000 - no paper in the rear tray. I don't use the tray very much, and there is no paper it it, and the access doors are both closed. I use the ...
