PIXMA TR4520 enlarge copy
Setup to enlarge copy
I know the printer is long in the tooth, but it's in great shape and still prints beautifully on a Windows 10 machine and an older Macbook Pro running Mavericks. Just got a M1 Mac Mini with Big Sur. There is no official IP4500 driver for Big Sur, an...
Hi I wonder if anyone can help me. When I print any A3 prints with coloured backgrounds, they always come out with a white line/band at the bottom of the print. (Picture attached) This only happens with coloured backgrounds and only when printing A3....
Hello-- I'm new here. I just registered because of this weird new problem with my MX922. All of a sudden, anything I print from a file on my computer comes out with a wide, blank swath of white vertically down the middle. If I change the print order...
Hi,I have strange problem with canon pixma g2420. It was printing everything after first instalation, but on the next day it started to have problem with printing images. It looks like this: - Printing images from pdf, word etc is fine doesnt matter ...
With my MP250 printer, when I try to print now shows in a box on my PC the message " Cannot communicate with the printer.Turn Enable bi-directional support on in the printer's Properties dialog box."Looking at my Canon desktop app there appears to b...
I had a paper jam, wich is completly and properly fixed. But I still have the 6000 error message. Because of the persistent error message, I cannot use the led display to get to the menu (to make the reset) How can I reset the printer, wich was worki...
IJ Scan can suddenly no longer scan from my MX922. My wife's PC and my son's Mac have no just problem. The error message is unhelpful. What should I do?
Hey I bought this because the Wifi was meant to be easy to set up. For some reason the software at ig.start.cannon just "can not acquire information about the driver or software". I have checked that the canon can access the internet through the d...
I have 2 Macbooks, both running Big Sur 11.2.2. 1. The 1st Macbook was running Catalina and had canon driver installed on it. It was then upgraded to Big Sur. The ability to click Scan exists. (See attached photo)2. The 2nd Macbook was bu...
I went to print a #10 envelope; never had a problem before. The envelope got jammed and is inaccessable from either rear of front. Cannot even be seen, so likely mangled inside. Is there any other way to get to and remove the jam?
I just got this printer MG3650 and installing on windows 10: i have downloaded the driver and everytime i load up it fails : FAILED TO ACQUIRE INFORMATION ON THE DRIVER AND SOFTWARECHECK INTERNET CONNECTION i have gone through FORUMS and tried ever...
My G3020 printer takes too long to switch off. What should I do? Please help.
I have a canon 920 series. I have always been able to scan. THe printer will not scan get error code:5,156,69 that the printer is off or usb not connected. Which is false because I am able to send documents to printer to print with no issues. I ...
My MX922 copy function produces a blank page. I can see the image on the preview screen, but the output is completely blank. I have checked, all nozzles are clean - I can print from computer, but placing a document on the glass and trying to copy onl...
| Subject | Author | Posted |
| 09-23-2026 07:16 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
