Pixma MX492 Error Code B204
Just received this error code today, first time to see this. All I did was move my printer to dust undeneath and now the code shows. What is he issue and how to correct?
I have a Canon TS8322 and it keeps coming up with "Paper Error 1303" there's no paper anywhere, I've restarted, I've taken the paper tray out and retried. Nothing's working, I've had this printer maybe 3 months and never had this issue before.
Scanner not working, although Computer HP Pavilion x360 says scanner driver is working fine.I don't know enough to know what I am missing or where to look next. No issues with printing wirelessly. Just scanning.I purchased HP laptop in January and be...
This is bizarre. The old cartridge was full. I put a new one in. Still no dice. I've cleaned and deep cleaned the head - but it won't print from the PGBK. The test page has perfect color in the D section, but the C pattern section is blank. Thi...
My new MacBook Pro just updated to Big Sur. It recognizes and can print to our Pixma MG7520, I assume via our home WiFi network or maybe AirPrint. But today I went to scan a photo for editing on the Mac, and realized that apparently only the printe...
I just bought a brand new black ink but its printing green? If I printed something from mircosoft word it comes out black but if i print from something else like a screenshot or USPS tracking, it comes out green. what should I do?
Hi, It is not recognizing the paper so it grabs it for a moment and then shoots right out. I put one sheet upside down by mistake and printed fine on the back of the labels. It will print the file fine on regular paper . There is no display on this m...
Hello all you people with printer problemsI am using a Pixma MG2560 in conjunction with an iMac running OS Catalina 10.15.7.The printer decided out-of-the-blue to print only in the top left corner of the sheet.The printer settings look ok to me.Any i...
Hi. I want to print a direct image onto a printable CD using the MX922. I am using an iMac running Catalina 10.15.5 or a MacBook running Mojave 10.14.6 On the iMac, My Image Garden crashes when I select a CD project. On the MacBook, My Image Garden...
Hi, can I undo the "quick setup" for my new TR-4520 printer? I made a mistake (I didn't select the option to connect to computer). I also didn't finish the quick setup. Now all I can do is make copies. How can I just go back to the very beginning, an...
I have a model MG5422. The 1681 error appears constantly. I have changed all my ink cassettes. It has not helped. I cannot print or perform other functions. I did follow the owner's manual powering down and powering up. I have also disassembled ...
Can't get drivers or even REGISTER my new TS3522 printer because I'm finding no Serial Number that the Product screen on Canon's site will accept. On the back of the printer, right beside a barcode, is a number "QC7-1389-DB01-01" and a number further...
Until recently I have had no trouble accessing and using the MF634cdw scanner from within either Paperport or PaperScan. Last week I added an Epson FF-680W and I could no longer scan using the Canon from those apps. ScanGear is called by those apps a...
When I press the wifi button the power light stays on... it does not start to flash. (PS my work IT guy spent 2 hours trying to set up this printer for me and was unable to)
Model: Canon Pixma ts6350 Problem: PGBK (probably), the bigger the letters the more visible white stripes, sometimes there are gaps between regular size letters too. It all started about week after purchase, I set it up, printed some test documents a...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
