Question regarding Canon Printer MG 2520
When I print a document, I first get an alert that says, "The ink absorber is almost full." However, I press the "Start" button and the document prints. What is the "ink absorber?" Can it be replaced?
I was getting message about the toner being low, so I decided to go ahead and replace the cartridges. That gave an error "Install ink cartridges correctly" 168A. That was odd because there isn't much to installing them, just push them in until you he...
an old post stated very similar issues. after incorrectly dealing with a paper jam, i got a similar error message, "there is no paper in the cassette". i too opened the lower cassette to find a small square piece of white plastic on the paper that...
Good evening. I am trying to figure out why my printer will not reset after changing all of the ink cartridges. I am getting 4 flashes on the error button, which will not reset. I have reinstalled the printer drivers. I have unplugged the printer...
My G3610 has stopped using red ink(M) when I print.If I lift the table I can see the tube line is actually empty 'ishHave done multiple Deep Head cleaning to no availDoes anyone have any ideas?
I'm using an iMac with a G4210 printer. I cannot figure out how to duplex or print double sided. In the printer dialog box there isn't an "Duplex" box available to check, only a "Black and White" box. And lower under "Layout" there is a "Two-sided" ...
After months of sucessful usage, printer will now not advance beyond the page that allows selection of printer to be used. I've not changed or added any programs. My browser is Chrome 91 and I 'm using Windows Version 1909
I bought a Canon Mega tank printer hoping it would save me money in the long run. I use it often to print b&w, and also photos. It worked fine one day, and the next when I went to print photos it only printed in black and yellow. (the tanks are full)...
I've had the MG2220 printer for several years now. It's been awhile since I've access My Image Garden. I opened it to receive a message that something was missing and I needed to reinstall. Which I did. Many times. What is happening is once it g...
Hi. My MX926 goes through a lengthy preparation before every print job. This involves much clicking and whirring and print head movement and takes a long time. There is also a lengthy pause before even starting the preparation. This means that it tak...
We had a paper jam in our Pixma MG5650 printer. We removed the crumpled paper, but there was clearly a blockage at a specific point. Subsequent sheets just crumpled at the same place.After trying various things, as a last resort we took a laminated...
hello! i have the pixma ix68650 and i am trying to print out some fine art prints on high quaility cotton matte paper. The Colours are perfectly sharp and vibrant but the black lines have a jagged edge to them. the adobe illustrator file is all in ve...
All the sudden my printer started printing pages diagnollt. The printer will not pull the pages evenly. It is the Canon TR150. Im going crazy!!
I use canon e500 printer. when i try to scan using auto scan in my desktop. it says: cannot scan for these reasons 1.) scanner is turned off 2.) USB cable is disconnected Code: 5,156,61. I checked my USB cable and it is connected. I try to restart my...
I am trying to copy a 6x4 photo onto 6x4 (15x10)photo paper but for some reason the printer enlarges it cutting off approximately 8mm at the front but only 4mm at the back, bottom and about 3mm at the top.I have spent ages on line chatting to their ...
| Subject | Author | Posted |
| 09-18-2026 11:59 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
