MX490 power recycling
The fix as presented by Canon actually does work. It took a while to execute the procedure properly. But it works.
Same issue as all the others. Tried to print 6/1/22. It would cycle through for a few seconds and then turn off. As someone mentioned in another thread… I am able to print again only after disconnecting wifi/router. I then was able to restart pri...
My Pixma MX452 is stuck in an initialization loop. When I turn it on it beeps, displays "Canon" in the display, and the scanner begins to move. Then it repeats this, endlessly. The only thing that stops it is pressing the stop button, but when you ei...
Got the double printing / shadows problem and cleaned the encoder and tried the print head alignment countless times. The very first time I tried the alignment I was asked to pick the best one and it never happeneded again. I didn't pick anything be...
My lap top has windows 11 and my printer MG2522 will not get past the printer connection screen it’s says it’s connected just won’t pass it. I’ve tired everything it’s said to do but nothing will work
My printer was just fine until around two (2) days ago. It began to turn on and it would do all the usual steps to get ready to print, but then turns off. Now here's the biggie on this one, you will not believe it. I accidentally turn off the "breake...
Now going on 4 days! This issue affects a great deal of consumers, not just one particular model. I used to think of Canon as the gold standard in printers. Now I have to be a computer programmer to "fix" the issue. That's ridiculous.
Can anyone who continues to have the constant on/off cycling problem when linked with internet tell me what canon is going to do about this?
My MG2522 wont get past the printer connection screen it says it’s connected just won’t get pass I’ve tried almost everything was wondering if anyone else can anything that could help.
MG6620 latest firmware V03 update failed yet printer status says printer is uploading firmware. Stop error light is flashing while the on button is off. How do I fix this?
I have a Canon Pixma MX 490. When I turn it on, the green light flashes and it makes sounds as if its printing something (even though I'm not). The message just says "Canon" and I can't press any of the other buttons, it's not responding to them. Whe...
I've seen similar posts but no solutions. Recently my printer (MG3520) has been printing all my b&w prints (which were originally b&w - not converted color) as sepia or browish colors. In some cases that might be acceptable but these look awful.I've ...
I am literally about ready to throw this printer out of the window! Let me start from the beginning. I got the printer approximately six weeks ago and the installation went perfectly smooth. I had no issues until I changed networks the other day. ...
I have a Canon TS3522 printer. Bought it, hooked it up and it was great. I moved and went to set it back up, can't get it to connect to either my laptop or my android. I have the same WI FI as I had before, any suggestions? Please help?!?!
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
