Desktop Inkjet Printers
PRINTER PIXMA TS9020 DOES NOT PRINT
Suddenly, my printer does not print the Cyan color nor the Black color. I have performed 3 regular cleanings and several deep cleanings and this resulted for the grey color now not showing either. I must have printed the nozzle check pattern 10 times...
G4210 scanner scan bed copies misaligned
When I make copies from the glass on my PIXMA G4210 the output prints about ,75” lower on the page and therefore crops of the bottom of the page. When I make copies from the document feeder the output is fine. Also when I print from my phone or the c...
RbeforeE by Apprentice
  • 3295 Views
  • 2 replies
Canon TS5350 taking a long time to print
Hi guys, I have just purchased a canon TS5350, and after the first few uses it has started to take a long time to begin printing, making noises like it'll print for quite a few moments before sucking up a page, and then when printing the document it ...
Pixma MG2522 won't connect
When trying to install via USB to my HP laptop, running Windows 11, I get to printer connection. It originally says connected please wait, after a while it will say printer not detected check the connection. I unplug and replug the USB, it says print...
Resolved! MX492 lost "open scanner" dialog box
I'm using a MacBook Pro running OS Monterey 12.5.1. When I open System Preferences / Printers & Scanners I can see my MX 492 listed under "Printers." There was always a dialog box under the printer name that said "Open Scanner." This box is no longer...
MX492 only printing at 1/4 size (mac)
Hey all-My printer suddenly started printing at 1/4 of the size of the page. I checked the settings a dozen times, uninstalled and reinstalled the printer, and it just isn't working. I set the # of pages per page to 4 and then back to 1, and that wor...
meggo by Apprentice
  • 6170 Views
  • 7 replies
Resolved! PIXMA TS 6420 shuts off after a period of time
I want my printer on all the time.  I've spent over an hour trying the USELESS online manual and this support forum and I can't find a way to keep the printer on.  HELP!  The only help in this forum I could find for this issue is for a different mode...
BOBBYV by Apprentice
  • 5445 Views
  • 2 replies
MX922 error B200... can't get rid of it!
Hi, my Mx922 started to show the error B200 while printing a few pages. After turning it off, and on again, it shows the error as soon as it's doing it's "turning on" sequence. I did the trick of opening the panel and while the head is moving to the ...
taiandre by Apprentice
  • 922 Views
