11-01-2021 01:07 PM
The rear tray refuses to acknowledge the #10 envelope and tells me the paper size is not as listed but doesn't allow me to change the paper size to the envelope size.
12-21-2021 03:20 PM
Hi TERRYB,
To print on envelopes with your PIXMA TS9120, please follow the steps provided in the manual:
https://ij.manual.canon/ij/webmanual/Manual/All/TS9100%20series/EN/UG/ug_l_01_05_c.html
Also, if you are attempting to print envelopes using Microsoft Word, please use these links:
If you continue to have difficulties, please contact our support group using the following link:
https://mycanon.usa.canon.com
12-26-2021 12:59 PM
Thank you for the information. Though it was a good start it did not result in the problem being resolved. It seems that I had to go to a 'copy' of the installed printer to have it work correctly. As that happened, I would think it has to be a conflict between Canon and MicroSoft. Oh, the reason it took so long to reply is shortly after I posted and your answer I had my ssd ("c" drive for me) go out, resulting in a brand new installation of Win10. That is why I believe there to be a conflict in the two companies code.
