I used a Pixma MG3200 for a long time. As part of my use, I had installed the supplied software, and IJ Scanning software. Recently I upgrated to a Canon TS3120 printer. I deleted the MG 3120 printer here on my mac. I think went into application...
I am trying to print through apple pages and all my photos come out heavily Magenta. I have printed a test page and all nozzles seem to be printing fine. Have checked ICC profiles and they seem to be correct as well.Have read a lot about double color...
so i just got a canon TR8622a, normally go with hp but decided to give this a try. got it all setup and connected to wifi router and have direct connection wifi turned on as well for mobile use. had nothing but issues and still do. the laptop running...
printer wants to send fax instead of printing why
The characters are blurred. When viewed with a magnifier there are double characters offset slightly.I have tried alligning the print heads with no success. There is reference to aligning the heads manually but I could not figure out how to do this. ...
I have had an ip7220 for 5 or 6 years that I use to print CD/DVDs and color photos. It has worked very well until I got an error code B200. From this forum I found that it meant that the printhead was the problem. I removed the printhead, cleaned ...
Good morning. I purchased the above referenced printer after verifying that it did indeed have drivers for my Operating System.So I am running Zorin OS Linux Operating System which is based on Ubuntu Desktop. I installed the CNIJ drivers downloaded...
How to make single sided printing the printer's default mode?No mention of it in the manual that I could find. Anyone know how to do it for this model?
i can connect and print but trying to change time off settings this is what i see
Hi all, I'm new here and i'm having trouble with my new pixma mg2522. I've been trying to print a document that is the standard size 8.5 x 11 and when it prints it is cutting off in the middle of the last line of text on the page. The formatting is t...
my PIXMA was turned on, and working fine, we had a power outage due to wind, when power came back, my PIXMA was On - light was green But it will not turn off. It is stuck in the on position. I have unplugged it from the back of the printer as well a...
Hi!I bought a Pixma TS3522 printer and when turned it on an error code P22 appears. I have been unable to complete the setup. Thanks.
I recently purchased a Canon TR8620a printer on Amazon for use in my home bakery: It is only printing in black - no color. I installed all of the edible ink cartridges as instructed. Nothing in the Canon library deals with this situation. Are ther...
Hi, no problems with my canon printer until today when it says it's offline even though it's powered on and so I go through forums and realize maybe my firewall is on so that's the issue. I try again and it's still not connecting and still not printi...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
