11-24-2017 03:11 PM
Hi. My usually reliable PIXMA MG3550 had a paper jam for some reason. I opened the back to get the paper out, now everything I print is coming out double exposure but only in places. I've aligned the print heads, updated drivers and checked out the mechanics of the paper release drawer at the back but nothing seems to work. Any ideas? Thanks in advance for any help.
11-25-2017 06:29 AM
I ended up fixing my own problem with help from https://youtu.be/bY4_P1IBiRM. I took a glasses wipe to clean the encoder. I hope I've helped someone else out there.
11-25-2017 06:29 AM
02-05-2019 11:08 AM
Hi, I have the same printer and the paper just wont feed. I've cleaned the rollers but I think they aren't even moving which I think is the actual problem I have now identified. The printer turns on, but every time i try to print or photocopy something I get an orange flashing light that flashes twice. Which, according to my research corresponds to paper not feeding. But if the rollers at the bottom won't even roll I really dont know what to do. Can you help?
01-19-2022 06:24 PM
A similar thing happened to me after a paper jam, with blurry and uneven printing and a white strip on the paper. None of the usual measures, such as cleaning print heads, realigning the print heads, removing and replacing the print heads, worked. I cleaned the encoder strip following the video posted above and it works perfectly now. To be more cautious, I cleaned the transparent encoder strip with a lens wipe (not my fingers, as shown in the video).
