PIXMA MX340 Produces Yellow Copies
Have printer set for black ink only of which it does but when copying the printing comes out yellow. Thaks for respone
I keep getting error message 7700. How do I correct this to get my printer to work?
My grandma gave me her canon mp600 saying she's having a problem using it so I took it home. When I turn on the printer it shows Error052 message. I did remove all the print cartridges and trying to remove the printhead and put it back but it's still...
Hello Community,It's not a big thing, but Canon's online manual is of no help, but hope this forum can help.I inadvertently enabled Wifi on this printer, but I'm using the hardwired USB connection and don't want the wifi version. But I find no way to...
I replaced my black ink cartridge but the Ink level keeps saying its low and won't print in anything but color how do I fix this?
My Canon TS9120 keeps giving me Support error code 1851 even though the tray has been pulled out. I have tried numerous solutions but none have worked
Hi everyone, I just got a TS6420A all in one wireless printer. I want to print a 4x6 image on an 8.5x11 paper. It appears that the Canon inkjet smart connect app only prints the image to the size of the paper selected???The easy-layout app allows you...
Using ip8720, when I set the height to 4.25 in Custom Paper Size the image does not print correctly. If I let the printer set the margins, I get the message "The paper size limits as defined by the PPD are a minimum height of 5 inches..." If I set t...
I have a pixma mg2522 printer about a week old that I hav hardly used and already the estimated black ink level is less than half. My old Brother printer's ink cartridges lasted for month with frequent use. Is this to be expected? If so, I need to re...
recently purchase canon pixima printer all in one tr8620a i got a eror code 6004 and i cannot get it rrsolve i shut the prine and turn it on again but nothing
I have a Pixma TR 4520 printer/scanner. I can print from another device just fine. When I try to scan it shows a wifi signal but I get a message saying signal strength is poor. I moved the router to be directly next to the printer with same result...
Issues with printing test page or files from PC.. Removed from Control Panel/Devices and Printers. Reinstalled.Rebooted printer-powered off printer w/ 30 sec wait.Still getting error 1003 and 01Still not printing test page.
If so, where would I find it? I'm sending images from Photoshop, and the TS5320 is printing out darker images. No, my monitor is not calibrated. I'm currently using sRGB. I went on the Canon site and found ICC profiles for the Pro line.
I cannot install the MP scanner driver since W10 22H2Printer is an MX 925 on network connected with WiFI, computers on Wired network.All IP-adresses is staticI allways receive the same error message "Cannot create Port".Printing is Ok, With Canon MP ...
Hello Canon,Just unwrapped my new printer with a specific print task in mind. I'm trying to print PDFs that have sheet music on them at a slightly larger than default size. I have gone to settings and tried a bunch of different print options but noth...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
