Desktop Inkjet Printers
Pixma TR4520 Outputs blank pages
Print is using a cord to a computer but will go through all the efforts of printing something but then it's blank. Same with copying. It scans fine. It started months ago so I stopped using it. but now I REALLY need to print some things in color.
Canon Pixma TR4720 setup on Chromebook
It says this printer is compatible with Chromebooks.  When I try to set it up and select Canon as the brand the model does not show.  No Pixma models show.  What do I select for a model?  I am running Version 113.0.5672.134 (Official Build) (64-bit) ...
reg00000 by Apprentice
  • 8677 Views
  • 3 replies
  • 1 likes
Canon TS8360 - scanning unit Open error
I had a paper jam in my Canon TS8360 and have since removed the paper. The scanning unit is close, but there is a caution unit on the screen that says"The scanning Unit (cover) is open. Close it!" I have opened and closed it several times, turned it ...
White Lines Through Text
I am seeing white lines through various lines of text.  The lines are always at the same place regardless the font.  I've cleaned and recleaned, aligned and realigned so many times I cannot count.Any suggestions?
tct2125 by Contributor
  • 1269 Views
PIXMA TS3522 Scanning Error
I just bought the Canon  Pixma Ts 3522 and I have used it several times to print things but when I try to scan  it says their was an error. I read the drives needed to be installed/ updated so I went to the Canon website and downloaded the only drive...
