Desktop Inkjet Printers
G7020 Ink Problems with Large Print Jobs
All of the ink tanks on my printer are near full. If I am printing a small job (a few pages) everything prints fine. When I go to print a large print job (20+ pages), it starts off fine, but then it seems as if it runs out of ink. The pages turn pink...
aiglazar by Apprentice
  • 1623 Views
Can't Scan Documents to Computer - Pixma MG2520
Hello,I have the headache of Code 15, 156, 1Cannot communicate with scanner for these reasons:- Scanner is turned off. (its not)- USB cable is disconnected. (also not)I am on MacOS Ventura 13.5.2 using IJ Scan Utility2 Ver.2.4.1 (Mac)My attempts of r...
Canon TR8620 Can't detect paper after update
Hey I printed something and noticed the ink looked discoloredSo I went into settings and saw there was an update.I executed the update and then when I went to run a test print the printer refuses to detect paper.I've tried restarting, re-aligning the...
PIXMA G6020 Color not printing correctly
I've had a lot of issues with the G6020 since purchasing, even having to get a replacement within a few months of purchase. I'm normally able to figure out a solution but cannot today. I have gone through every maintenance step available. The ink tan...
MG2500 PIXMA cutting off sides of PDF
Okay...so I was emailed a nice certificate (PDF) to print off. Akin to like a graduation certificate. It's oriented in Landscape, and has a nice border all the way around it. ALL I WANT TO DO, is print this PDF off without it cutting the border off. ...
MX882 code B200 error
Hello. I hope I'm in the right section. My Cannon MX882 suddenly stopped printing. When powered on, it shows a B200 error code and a message to turn printer off and call for support. When this first happened, I tried rebooting and left the printer un...
Canon IP8720 banding
IMG_8479.jpeg Hi! I just bought a used IP8720 to print my bw images. The previous owner used off brand ink, although I just replaced it with new oem ink. Furthermore I cleaned the head/aligned it in the printer but it is still banding pretty bad. Doe...
Nateav by Apprentice
  • 1277 Views
  • 0 replies
TR7520 Support Code 1660
My screen keeps saying 1660 that its not reconizing the Ink cartridge and ive bought the same kind that ive used before and there was never a problem. Ive removed and put them back in and its still saying the same thing.
