09-25-2022 07:52 PM
how do I set up rear feeder printing? I set up the paper settings, but the printer won't register, only printing from the main feeder
09-25-2022 10:45 PM
Hi jfiorentino!
To have a better understanding of your issue, please let everyone know the operating system on your computer. Any other details you'd like to give will only help the Community better understand your issue.
If this is a time-sensitive matter, please check out your other support options here: https://canon.us/MyCanonAccount
Thanks!
09-25-2022 10:51 PM
of course - I have a MacBook Air (M1, 2020)
10-05-2022 09:16 PM
Just bought one. Same issue. I'm returning it this weekend if I'm not provided a solution. This printer was way too expensive to not perform as advertised.
10-01-2023 01:41 PM
mine was working just fine 2 days ago....then it stopped feeding from the rear and tells me that my cassette is not in. Any suggestions? Ive tried resetting but it is beyond me. is it broken? It is brand new!
10-01-2023 01:57 PM
did you ever get this resolved? My rear feeder was working perfectly and then it wasn't. it is brand new. I've tried everything, reset everything. Really need to figure it out! Help!
10-01-2023 01:59 PM
Mike-I am having the same issue. The rear feeder was feeding card stock a few days ago, and now I set it up to print and it starts make noises and then tells me that the front cassette is not in with error code 1871 ....the front cassette is not supposed to be in so that it bypasses to print from the rear. Why is it no longer working????
10-05-2023 08:32 AM
Please try these steps:
1. Press the gear icon at the bottom of your PIXMA TS9521C's display
2. Tap Feed settings.
3. Tap Detect paper setting mismatch.
4. Tap Disable.
5. Tap the Home icon in the upper left corner.
Attempt to print.
