Desktop Inkjet Printers
PIXMA TS3320 Trouble getting it set up
None of my Windows 10 Canon software, nor my Canon PRINT app can currently connect to my PIXMA TS3320 printer, so I'm left with manual configuration to try and correct that.  But when I press the Setup button on the PIXMA TS3320 console, it simply cy...
gherson by Contributor
  • 6859 Views
  • 7 replies
Resolved! Error code E59 on PIXMA TS3522
Error code E 59 on PIXMA TS 3522 - I have had this printer a little over 1 month. It has printed less than 50 pages, Now it won't print anything!! Will a factory reset resolve this problem? About ready to take it outside & smash it!!
Canon G7020 - really poor color printing
Hi. I have had this G7020 for under a year, and have consistently had issues with printing multiple color copies. Generally, the one or two will print fine, then if I run multiples they look like I've run out of ink. I've cleaned the print heads, dee...
Ame by Apprentice
  • 1323 Views
TR4720 Error code 1500
I have a TR 4720 printer and the ink is jammed and won't move. The error code says paper jam not there is no paper and the ink is to the far left within the printer casing and I can't even move it manually. This all happened after I replaced the ink ...
Resolved! PIXMA MP560 Envelope ink. smudging problems
I printed my wedding invitations on a Canon PIXMA 560, and they are absolutely beautiful. But when I I tried to print the envelopes, there is always a dark smudge of ink on the lower right-hand side of the envelope. I have done maintenance cleaning, ...
PIXMA TS3522 compatibilities on MacOS 14 Sonoma
Long story short, I bought a M3 MacBook Air a few months back. I've tried everything, but for some reason, I cannot get my PIXMA TS3522 to work on MacOS 14 Sonoma. I get error messages every time I attempt to print. I had to use my tablet to print mo...
printer will not print from my computer
The printer will do absolutely everything except actually print out from my computer.  Everything on my computer and printer looks like it will print but nothing comes out.  If I cancel printing then a small cropped image will come out. It will print...
heatherj by Apprentice
  • 1211 Views
Brand new PIXMA TS9520 giving error message 6004
We just received our brand new PIXMA TS9520 yesterday.  While following the instructions, when I hit the start button, the machine makes a loud noise and gives me error support code 6004.  I noticed that the ink tank area does not move when I click t...
PIXMA MX492 has no display
Hi, my PIXMA MX492 is about a year old. It was printing well until recently after I changed the settings to print envelopes. After restoring the prior settings and plugging it in, the power light is lit but nothing appears on the  display screen.   I...
JBH1294 by Apprentice
  • 6169 Views
  • 6 replies
Resolved! PIXMA TS3350 Don't know how to use it
I have the above printer/scanner but I cannot operate it, why? I've installed everything but do not know how to scan, print or in fact do anything with it. The instruction manual is next to useless, only telling you how to set up. I've important medi...
