Desktop Inkjet Printers
Scanning multiple pictures
HiI would like to scan a number of pictures using the sheet feeder on my Imageclass 8380CDW.I need to be able to specify the picture size being scanned (3x5 photo). I have the unit hooked up to my mac (via USB) and and a PC (via network), I am able t...
esigal by Apprentice
  • 3780 Views
  • 0 replies
Canon MX712 glossy print issue
MX712 printing all glossy paper with blue instead of blacks in rear tray - front tray standard comes out ok but wont let me do high quality glossy through front tray - strange.  did all cleanings, new ink etc..any help  thank u !!
APaul73 by Apprentice
  • 4944 Views
issue printing DVDs with ip7250 printer
I'm having an odd issue trying to print direct onto some  Verbatim printable blank DVDs - whatever the layout colours, including using photos (they all preview & display accurately) the end result is always pinkish monochrome image - it's tonally cor...
PIXMA MX922. Reverse order printing
I'm running Mac OS 10.10.7 and trying to print a long MS Word 2011 document from my computer-- in reverse order. I've set the overall Word Preferences to reverse order printing. I do not get a Print dialog box that allows me to select reverse order f...
KLS by Contributor
  • 6056 Views
  • 0 replies
print order
Why does MX922 print out a document in this order: i.e.,1,3,2,5,4,7,6,9,8,11,10,13,12,15,14,17,16,18? Mod Note:  Removed email address per forum guidelines.
MG 2922 paper jam
MG 2922 has constant paper jam and has only ever printed 2 sheets of paper.  The paper will not feed in to the printer either.  What can I do?
Canon stupidity...
If the OFFLINE STATUS alert has been a problem for years, prior to my buying a Canon Printer, as evidenced here and all over the web, then why does my Canon printer have this same  issue?  My point being, why hasn't Canon fixed the problem prior to m...
STATUS: OFFLINE. MG5400.
I have a lot of my time invested in finding a solution to the dreaded and common problem of not having my CANON printer turned on.   I have connected USB cable, deleted and replaced drivers, and CANON cannot even figure out how to turn on their devic...
