Getting PIXMA G3270 to turn on when print data sent
I have a PIXMA G3270 printer. When I got to print the printer does not turn on automatically when data is sent. How do I turn this option on?
The message you are trying to access is permanently deleted.
I have a MG 3620. I just bought it in 2023. It has said low ink since I installed the first printer cartridge. It's now saying no ink.
I bought a PIXMA 6020 printer/scanner. I hooked it up to wi fi and the print function works. When I try to scan a document it says the computer is not connected and defaults to Local (USB). The computer is connected or the printer wouldn't work. ...
We just received our brand new PIXMA TS9520 yesterday. While following the instructions, when I hit the start button, the machine makes a loud noise and gives me error support code 6004. I noticed that the ink tank area does not move when I click t...
My 2 year old Pixma TR8620a inkjet printer is connected to my Windows desktop PC via USB printer cable. The other day, it stopped working and the following error message was displayed: "USB Device Not Recognized. The last USB device you connected to ...
Long story short, I bought a M3 MacBook Air a few months back. I've tried everything, but for some reason, I cannot get my PIXMA TS3522 to work on MacOS 14 Sonoma. I get error messages every time I attempt to print. I had to use my tablet to print mo...
Hi, my PIXMA MX492 is about a year old. It was printing well until recently after I changed the settings to print envelopes. After restoring the prior settings and plugging it in, the power light is lit but nothing appears on the display screen. I...
I have the above printer/scanner but I cannot operate it, why? I've installed everything but do not know how to scan, print or in fact do anything with it. The instruction manual is next to useless, only telling you how to set up. I've important medi...
I've had this issue for well over 2 years but recently got pressed to solve this again. Wasn't able to contact support because I didn't know the purchase date of my canon device. (2015 sometime)Plan to call support this monday to attempt to solve thi...
I just recently purchased the TS6420a desktop printer to replace an outdated HP printer. This means I have to switch from the HP instant ink program to the PIXMA Print plan. I have signed up for the program and created my account. Wireless printing h...
My G6020 prints too faintly to read. I can't tell how much black ink I have because it's all black on black. I try to refill the ink supply and nothing flows from the bottle. I've cleaned, I've flushed to no avail.Any thoughts?
I'm leaving this here in hopes that I am not the only consumer who is greatly frustrated with the G7020. Somewhere between Canon & Pixma, I truly hope that the designers/engineers involved in this product will get this message. I was (and still am...
Hello.The yellow is not printing properly.I printed the nozzle check pattern. Made a nozzle cleaning.Repeated the process 3 times. I still have the same problem.What also can I do?Thank you
We recently purchased the G6020 all-in-one printer and we cant see the display screen on the panel without using a flashlight. Does the printer have one and how do we turn it on? It makes is a real hassle! Thanks
Subject | Author | Posted |
08-14-2024 07:23 PM | ||
08-13-2024 01:22 PM | ||
08-13-2024 12:46 PM | ||
08-13-2024 09:26 AM | ||
08-12-2024 02:34 PM |
