Desktop Inkjet Printers
Pixma mg7120 address reset for scanning
I recently moved from Norway to the US.  In Norway I had a european model of the Pixma mg7120 printer with my laptop setup with the various Canon programs to allow for printing and scanning (all worked fine).  Since arriving in the US I have purchase...
allrerd by Apprentice
  • 5397 Views
Scanning Problem MX410
I'm trying to scan via ADF to a PDF file on a window 8 PC.  Go through the promps on the printer scan to PC , select PC local USB, document type auto scan,  Then display show PC scan standby.  It will not continue from this setting.  If I press start...
renttibw by Apprentice
  • 8931 Views
pixma 330 fax output error check paper size
I received a fax on my Pixma 330. The document came through fine, but now I have "fax output error, check paper size and press OK". The paper size is correct, and when I press OK, it prints out the original document again, then gives me the same erro...
JWK by Apprentice
  • 5803 Views
MX922 Scan from panel location.
Hello, I'm triyng to change the defauly folder location for documents scaned from the control panel of the printer.  I first chose the computer to scan to, it scans and I hit okay then the pdf shows up in MyDocuments. If I use the scan utility it wil...
nezoic by Apprentice
  • 6476 Views
  • 3 replies
